    Feb 2006
    Hi i want to use dvd-shrink to burn dvd but open those dvd files from my hard disc and i want to add a dvd menu but i dont know how.
    Coz in the dvd-shrink pogram there is no add menu ...buttom i can only add img files..so wat should i do? should i burn those files and the menu i a dvd iso and then open the dvd disc or is it any better thig to do...
    Zoe
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You neeed an "authoring" program...DVDShrink is not an authoring program.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...neither a burner program. Take a look at TMPGEnc DVD Author (30 day free trial)
    /Mats
    Feb 2006
    ive got that TDA pogram but i can only burn 3 chapter in 1 dvd i want to burn 10 chapter....
    and the dvd-shrink can do that..
    so please more advice..
    thanks
    zoe
  5. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    thanks
    zoe
    Huh? In TDA you can set as many chapters points (within limits) as you want. Also, there are precanned menus that'll display 15 chapters per page.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You're talking about those 10 episodes (from another thread)?
    First encode at the correct bitrate to make all fit on one disc.
    Then, in TDA, you add each mpg as a new title.
    Within each title, you can set chapter points if you want to.
    If TDA only lets you fit 3 episodes, you've encoded at a too high bitrate.
    /Mats
