Hey guys...
Working with DV footage and was wondering what your opinions are about these two encoders. I don't really care about speed, just quality.
One thing I noticed...using both encoders default NTSC DVD templates, TMPGEnc outputted filesize half the size as Sony did!!!! (audio was set at the same bitrate).
Well...please let me know what you all think.
Thanks!
Default bitrates aren't any indicator of encoder quality. You need to set average bitrate to the length of your program. Use the bitrate calculator.
https://www.videohelp.com/calc
Next take a sample of the video you want to encode, and set both encoders to the same CBR or VBR (max, average, min) rate and then see which you like best.
Vegas NTSC default is what you tell Vegas it is. I think out of the box it was set to
720x480 29.97fps VBR, single pass, (8000/6000/192 Kb/s), 224 Kb/s audio.
Plug that into the calculator and you get 1 hr. 38 min to a single layer DVD.
Have fun comparing.
PS: For DV source and max quality you would choose the following for 1 hr.
CBR ~8225 Kb/s + 1.536 Kb/s for PCM audio, or
CBR ~9570 Kb/s + 224 Kb/s for compressed (MP2 or AC-3) audio
If going for 2 hours, I'd use
Two-pass VBR (8500/4850/192 Kb/s), 224 Kb/s audio.
Camcorder video will look best if you use a tripod and control your pans and zooms. If it is handheld shaky stuff, go back to 1hr CBR.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Render settings questions for MainConcept/AVC/AAC (*mp4) in Sony Vegas
By vid83 in forum EditingReplies: 10Last Post: 22nd May 2011, 03:55 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Vegas Video via MainConcept H.264 to XBOX
By tobyjordan in forum Video ConversionReplies: 3Last Post: 10th Dec 2007, 22:37
