    Feb 2006
    India
    I waswondering today if it is possible:
    make fancy menus in sonic dvdit or mydvd 6.0 for movies which r not in vob format(coz dvdit and mydvd dont support vob i suppose)
    then burn dvd folder to hard disk and abort process when dvd menu has been outputed and the movie transcoding is started...so that i have got my menu for dvd (ahh yes very nice 1 from those 2 softwares)
    then i put my converted movie files (vob)in the same sequence i have done to make menus and then burn the DVD
    is this possible so that i can have nice piece of DVD with fancy looking menus
    Sorry but i cant experiement this coz dont want to waste a single DVD
    but i can wait for some hourse to get answered
    Thx
    Apr 2004
    Miskatonic U
    You can exepriment because you can always playback form the HDD first (which you should do before burning anyway).
    It probably won't work, or if it does this time, it may not next time.
    Why don't you demux the VOB files back to video and audio so you can uathor properly, instead of trying to pull some stupid trick to save youself a few minutes ?
    Read my blog here.
    USA
    DVD Menus are made in an authoring program. If you want fancy menus, you should look to programs like DVD-Lab or DVD-Lab Pro or similar. A simple authoring program is TMPGEnc DVD Author. If your program is just an encoder and doesn't output VOBS, IFOs, etc., it doesn't sound like it's an authoring program.
    Look to our guides to the left under 'AUTHOR' to see methods to do what you want. <<<<<<<
    Apr 2004
    Miskatonic U
    I get the impression is he happy with the menus these simple programs churn out, however his videos are in VOB format (probably because he used something like WinAVI to create them) and his authoring software can't import VOB source material.
    Read my blog here.
    Feb 2006
    India
    well making a dvd in mydvd or dvdit take ages to complete ( i think it take around 5 hours on mmy pc to finish transcoding 4 gb dvd video)
    ok.. i ll have look at authoring guides
    any more comments
    thx
  6. Mod Neophyte redwudz's Avatar
    USA
    guns1inger, you may be right. I stay away from most all-in-one DVD programs for the type of problems he mentions.
    enli2, I use a separate encoder to produce the MPEG-2 file, then a separate authoring program to generate the menus and create the DVD format.
    If you want control over the quality and the look of your menus and of the finished DVD, the individual programs are generally the best way to go. We have lots of guides to show you how to do this, but it takes a bit of reading and studying.
    Apr 2004
    Miskatonic U
    You should not use an authoring tool that transcodes material that is already compliant.
    Read my blog here.
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Originally Posted by enli2
    any more comments
    Get a RW disc and you can experiment all you want.
