I have converted a .avi video to .vob using Winavi 6.0.
Usually it will convert into 1 dvd_0 folder but this video it convert into dvd_0 & dvd_1 folder.
What I would like to ask is why is it like that and how do I do to burn it to a dvd as the video after convert is splitted into different folder unlike other video.
Thanks!
How big are the folders? Sounds like it couldn't convert and fit onto one disk to me.
Also what is the total running time of the AVI in question? -
Dvd_0 is 242MB while Dvd_1 is 3.52GB.
The .avi video time is 1:17:09
I converted a video file which is larger than this one but it manage to convert into 1 dvd_0 folder only.
Please help...Thanks! -
It sounds like the problem is WinAVI. You might try DivxToDVD. It generally works better.
And check the AVI file with Gspot. If you see MP3 VBR audio, that may be your problem. Or drop the AVI into VirtualDub and it will tell you immediately.
That length of video should fit into a DVD fine after encoding.
Hi, thou there is no MP3 VBR which you mentioned in GSpot, but using convertxtodvd really helps and after using it, I decided to dump winAVI.Originally Posted by redwudz
Ooo...Originally Posted by guns1inger
what will it be? As usually just convert & straight away burn it to dvds.
How about any good programs to make those nice fancy dvd menus? This method is call DVD authoring am I right to say?
Can Ulead moviefactory 4 do the job?
Thanks for helping! -
Try using Thefilmmachine or Avi2dvd both can make dvdmenu's and are free to download
Video conversion queries
By AussieTuca in forum Video ConversionReplies: 3Last Post: 16th Aug 2011, 19:01 -
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 20:42 -
Some plasma TV queries: Panasonic G10A plasmas OK for SD?
By rossnroller in forum DVB / IPTVReplies: 14Last Post: 28th Jan 2010, 17:01 -
Anyone know SQL queries?
By sdsumike619 in forum ComputerReplies: 3Last Post: 16th Oct 2008, 20:37 -
PHILIPS DVP 5996 and DVP 5986 Queries
By anirban in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Sep 2008, 17:32
