I have taken old Hi8 videos of my son in track and put them through my Sony TRV30 to upload into digital format on my Sony Vaio with XP, 2.1GHz,Pentium 4, 80 Gig, 512RAM. Now I want to burn to a CD or Video CD in decent resolution so I can put it into DVD player or PC CD Rom. What is a good program for a beginner. I bought "Digital Studio" Software which has the "Video Wave" Software Program. Is this a decent Program?
Not familiar with that program. Most people here use TMPGenc (as it's free). You can d/load the newest verison (and it's VFAPI plugin) from http://www.tmpgenc.com
For best quaility... well this i a never ending source of debate
If your source runtime is less than 40min the easiest thing to do is to use the standard SVCD template and make a SVCD.
If your Hi8 source is interlaced, MPEG2/SVCD supports interlaced source, MPEG1/VCD does not.
Most DVD players can play SVCD, all PCs can play VCD or SVCD. However, while a PC can play a VCD w/ media player you'd have to d/load a MPEG2 codec/player to play SVCDS (see the play section to the left).
See the convert section to the left for more info on TMPGenc. -
Use TMPGenc to convert to a VCD MPEG. Then burn it with Nero. Or some other burning software. This site explains all of that in the How To Section on the Left Side of this site.
Burning & copying to portable drive
By thetemple in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2010, 03:59 -
Copying or burning a DVD
By njp1990 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2010, 17:04 -
copying analog 8mm to mac using sony digital 8 and firewire
By iampammyb in forum MacReplies: 4Last Post: 15th Nov 2008, 01:15 -
Problem burning/copying on dvd-r
By reminho in forum Authoring (DVD)Replies: 26Last Post: 12th Sep 2008, 01:28 -
Copying DVD and Burning on macbook?
By RobAdam in forum MacReplies: 18Last Post: 9th Nov 2007, 16:00
