Is ther one for TMPGENC?
I dont know how to do it!
please help
thanx
There are several. But understand that xVCD simple means non-standard VCD. Not better quaility! Sefy's templates are popular and can be found under the Tools section to the left. To make your own xVCD do a search or take a look at:
https://www.videohelp.com/phpBB/viewtopic.php?topic=70887&forum=3 -
I'm trying to ripe the highest quality that I can to play on my Sony DVP-S550D can you help?
thanks,
Newbie Dug -
Dug, the Sonys throw a wobbly if you do anything other than change the bitrate value or resolution for VCD.
Best thing to do is to load up the standard VCD template in TMPGENc and then load the UNLOCK.MCF template to unlock the settings.
Use the bitrate calculator on this site to work out a Constant Bitrate which will fill two (or three?) CDs. Then bump up the bitrate in TMPGEnc to the value specified.
You may also like to play with the resolution settings but I would suggest that you start off with the bitrate change first and then move on later.
Dug, just to warn you but you can get great quality by converting something but the better the quality to more hours it's going to take to convert.
Could i get a 720x480 res working? I just don't like the way the 352x240 looks.
thanks for the help guys,
Newbie Dug -
I've recently encoded several 352x240-captured and rendered MPEG-1's (using Pinnacle Studio 7) into 720x480's using TMPGEnc and the quality is somewhat better than the 352x240 was.
See the tutorial at http://www.vcdhelp/.com/tmpgencxvcd.htm . -
dmwierz, did you have them as 720x480 VCDs or what?
thanks for all the help guys
Dug
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 17:04 -
Adobe Encore - calendar template available?
By The Linguist in forum Authoring (DVD)Replies: 2Last Post: 2nd Jan 2008, 05:14 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 09:09 -
Substituting Variables in a Wiki Template
By thecoalman in forum ComputerReplies: 1Last Post: 14th Jul 2007, 05:00 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 19:54
