I'm a newbie to this suject and I was hoping you guys could help.
I'd like a capture device for recording programmes off Sky Digital and terrestrial TV from my television. I aim to store these recordings as data on DVDRs and play them from the PC on my TV screen. I don't plan to rack up large quantities of DVD movies or VCDs.
I've been looking at the Win TV PVR range, but even the 150 (which some of you guys don't seem to like anyway) is a bit out of my budget - I don't want to spend more than £50 if I can help it.
Obviously there is always the ebay route for a 250, but I was wondering if there was another range with a slightly cheaper (but still decent) base model.
Results 1 to 16 of 16
Show me a bored kid, I'll show you a lazy kid
I don't think you'll find any cheaper alternative with hardware mpeg encoding. (And that's really good to have, if you don't have a dedicated caprture computer.)
/Mats -
Okay, well is there anything similar to the PCR 150 that's reliable? USB or otherwise?
Show me a bored kid, I'll show you a lazy kid -
250 is stable as a rock. If you can find it at a decent price, get it. The prob with 150 was something with audio levels. Don't know if it's fixed in recent generations. IMO, internal <anything> is better than external <anything> if you don't plan to use <anyting> with several computers.
/Mats -
There must be more than one decent capture card in the price range of the 150/250 though right? Or do Hauppauge have the monopoly? I'm gonna try to get a 250, but they don't seem to be that commonly sold on ebay. I guess that's a testament to how good they are.
Not much in that price range with hardware mpg encoding, no.
/Mats -
Originally Posted by mats.hogbergShow me a bored kid, I'll show you a lazy kid
For Sky Digital you may want to use one of Hauppauge's digital sattelite cards like the Nova or Nexus series. These will capture the MPEG data directly from the satellite. These usually won't be ready to burn to DVD though (not the right frame size).
If you use one of the PVR cards you'll be using your sattelite receiver to convert the MPEG to analog video, then the PVR to convert back to MPEG. The down side is loss of image quality. The up side is that the MPG files can be ready to burn to DVD. And you can capture from other analog sources. -
Originally Posted by jagaboShow me a bored kid, I'll show you a lazy kid
[quote="Bizzen"]
Originally Posted by jagabo -
Originally Posted by flemming kristiansen
Sorry, I'm a bit lost now.
Here's some info on my TV I picked off the net:
Front terminals:
AV-3 S-Video In
AV-3 RCA AV In
AV-3 AUDIO IN 2 x RCA
Headphone Terminal
Rear terminals:
AV-1 SCART AV IN/OUT RGB IN
AV-2 SCART AV IN/OUT S-Video IN
Line Level Audio Output 2xRCA
Aerial (UHF)
I'm a bit confused as to what connection I can make from the TV now.
Can anyone advise on that?Show me a bored kid, I'll show you a lazy kid -
You connect the PVR to an output of your Sky receiver, not the TV. If there's only one output from the receiver you'll need a splitter.
You can take the signal from one of the two Scart outputs of the TV with a Scart/Phono cable. Then it will be only composite and since you have routed the original signal to the TV via an arial lead, youll get a very bad signal to the PVR. Aint there anyway you can lead the signal straight from the Sky box to the PVR? It will by far give the best picture.
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 09:16 -
PCIe/USB AVI Capture device with SVideo and fully functioning Win 7 drivers
By Spektre in forum Capturing and VCRReplies: 3Last Post: 23rd Aug 2011, 19:34 -
How to which audio output device a program uses in Win 7
By WinSpecToR in forum ComputerReplies: 0Last Post: 30th Dec 2010, 22:30 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
win xp audio device
By dvds2u in forum ComputerReplies: 8Last Post: 15th May 2007, 15:03
