I look at the motion menu of TDA, it sad you can use BGM ( I assume Back gound music ).
But where can I specfied BGM ?
1. add desired menü background video/image to TMPGEnc 2.5/3.0 as video
2. add desired menu music to TMPGEnc 2.5/3.0 as audio
3. encode it with DVD PAL or NTSC template
4. in TDA, enable from "Menü display settings", "Motion Menü" and "..BGM..".
5. at "create menü" click menü background and choose just created filedarling if there is no place for me on your desktop, i'll waiting for you in the system tray -
Step 5 is what I need.
It looks like I can click on a blank menu, and then click on the little [EDIT] button at the middle bottom, and specific my BGM. -
you can use that button too
Background audio/music
By web_smurf in forum Authoring (DVD)Replies: 3Last Post: 14th Sep 2011, 02:44 -
DvdRemakePro users, is it possible to edit a PGC w/TDA and then import back
By Denvers Dawgs in forum Authoring (DVD)Replies: 8Last Post: 23rd Jun 2009, 15:07 -
How to add background music?
By coody in forum AudioReplies: 2Last Post: 25th Sep 2008, 16:04 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 12:56 -
How to lower background music
By auroragb in forum AudioReplies: 3Last Post: 24th Jul 2007, 20:54
