I was fixing a "repeating sound" problem of my kids computer. When I folow the instruction and turn off directx-9 sound accereration ( to no acceration ). Now Direct-X 9 gray out all the control, and say the PC does not a sound card anymore !
At the same time, Power DVD also loose its sound. But the I still get made sound with control panel.
I can only fixed it with re-sinatll the sound driver ( an VIA vinyl sound chip on MOBO ), and re-boot.
From the sequence, it is an microsoft Direct-x 9 issue ( I assume turn off hardware acceration for sound ) will loose the direct X sound.
Is there a fix or work around ?
First I would uninstall Power DVD. Then install the latest sound drivers from the MB manufacturer or chipset. Then reinstall the latest version of DirectX. THen reinstall Power DVD.
You can also run the dxdiag program to check if directx is setup/running correctly.Google is your Friend
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Turn off ffmpegX progress sound after finished conversion
By c.eiermann in forum ffmpegX general discussionReplies: 2Last Post: 2nd Sep 2010, 20:56 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 08:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
