I have been experimenting with captures and I ran into some problems.
I am using VirtualDub 1.4.7. I set the deinterlace filter to combine the two fields into one. I was capturing at 29.97 fps.
When I looked at the captured files with Media Player any light colored object quickely moving across a dark background produced horizontal stripes at the light / dark edge. These stripes look like what I would expect on an interlaced display. But I set VirtualDub to deinterlace.
Shouldn't these stripes be gone? Am I doing something wrong. What can I do to remove these stripes? I am thinking that this is causing noise when I encode it to mpeg2.
Please help. TIA
Steven
First, if your capturing from a true interlaced source (VHS, TV program, etc) you can't really de-interlace it. There will always be artifacts where the fields are blended/forced together.
However, MPEG2/SVCD supports interlace source. So if you're making (x)SVCDs you do not have to deinterlace.
Interlacing problem?
By killerteengohan in forum DVD RippingReplies: 16Last Post: 18th Aug 2011, 07:24 -
Question about interlacing
By ayim in forum Newbie / General discussionsReplies: 10Last Post: 7th Nov 2009, 14:19 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 20:50 -
Interlacing
By koberulz in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 13:32 -
HD and interlacing hell
By jchansen in forum MacReplies: 2Last Post: 4th Sep 2007, 11:14
