i've been converting avi to (s)vcd/dvd w/tmpgenc for a while now and i'm pretty comfortable at it
i realizes that i can use filters w/virtualdub or avisynth filters to help make the video quality better during the conversion
so i thought i start using virtualdub to frameserve the video to tmpgenc
don't know muh about it so here's a few q:
which filters should i use when i frameserve to tmpgenc = virtualdub or avisynth
> if virtualdub
can someone provide a good sets of filters to use
can someone provide a simple tutorial
> if avisynth
can someone provide a script to use w/the filters
Probably http://neuron2.net/ is one of the best places for filters for VD and Avisynth.
You should realize that filters aren't generally to improve the video, but to fix problems with it. (I realize there are filters to do many things, this is just a generalization.) What do you want from the filters?
If you look at the tool page for VirtualDub, you will see guides for filters to the bottom of the page.
Using Avisynth is generally faster and more efficient than VD for filtering, but has a steeper learning curve. Same thing, look to the bottom of the Avisynth page for guides.
The quality doesn't really change with frameserving. But you won't have to create a 'edited' version of your video, so it does save time and hard drive space.
Export to FLV using virtualdub and frameserve
By itoo73 in forum Video ConversionReplies: 6Last Post: 5th Jan 2013, 22:46 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 12:16 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 06:24 -
Is it possible to frameserve with Virtualdub to MeGui?
By salidarius in forum Video ConversionReplies: 8Last Post: 13th Feb 2008, 05:41 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
