  1. request deletion
  2. Member Huxley's Avatar
    Adelaide Australia
    Try ffmpegx.
    Open the file with ffmpegx and select preview.
  3. request deletion
  4. This is obviously a high resolution h.264 (AVC) video stream in MKV container, and your CPU is not strong enough to play the file including the subtitles.
    On what OS are you ? Linux ? Windows ?
    Christian
    matroska project admin
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    But, this is the Mac forum. <runs ^_^>
    mercmisfire, did you try ffmpeg, or ffmpegx? And, it might be a good idea to fill out the 'computer details' part of your profile, so others can know more about your system and be better able to help you.
