  1. I have multiple 640x480 AVI files that I would like to write to one DVD disc that I can play in a standard DVD player.
    I've tried using Toast 6 but Toast doesn't do a very good job of adjusting the 640x480 image to a DVD format. The primary problem is image cropping, which is a hit when the video includes subtitles that get cut off.
    Is it possible to do the encoding of the AVI in ffmpegX to fix this problem?
    And if so, I was wondering what target format to use to get the best result from Toast 6?
    I noticed that most formats I drop onto the Toast 6 video tab still go through some kind of encoding that takes hours. I was hoping there's a format that I can target in ffmpegX that speed up the toast encoding.
    Any information would be greatly appreciated,
    FYI:
    Starting with:
    Multiple AVIs
    Video: mpeg4, yuv420p, 640x480
    Audio: mp3, 48000 Hz, stereo, 128kb/s
    Would like to end with:
    One DVD playable in a typical console DVD player
    Video and Audio: best quality @ smallest size for more storage
    Tools I have available to me:
    Toast 6 Titanium
    ffmpegX .0.0.9v
    QuickTime Pro 7.0.4
    -johnny;j
    Dec 2003
    Eugene, Oregon
    Not an answer to your question, but you might be better off buying a cheap DVD player that has Divx (MPEG 4) playback capability. You then can burn the MPEG 4 AVI's to ISO 9660-format CDs (or possibly DVDs depending on the DVD player's specs) without any re-encoding.
    Wait a minute, I see the video is 480p instead of 480i. That might not work with my suggestion. You'd have to check the player's specs.
