Well, i have 3 Movies , Shrek, Saving Private Ryan, and Final Fantasy:, Anyways, they ripped awesome and play in great quality and now i want to put them onto a VCD. They are in extremely near dvd quality in the DivX qualty their in, but when i put them on VCD, some strange stuff happens. I use the Nero Encoder i bought. When i play them on any computer or DVD Player after i convert it thru Nero it will play fine for the begginging, and then halfway thru it will start flashing about every 10 frames or so a very low low quality image, then be good, then flash. it's just a very low res blocky image. Anybody know why this is? Also after its encoded the sound loses sync near the end and it is interleaved so it shouldnt. Anyways, i couldnt find any settings for nero's encoding so if anyone could help i would like it.Thanks
why are you ripping your dvd's to divx? you'll lose quality just by doing that alone! try using dvdecrypter, dvd2 avi and finally tmpgenc to encode to vcd or svcd. dont use nero to encode leave that for the burning to disc. regards......dave
how to encode?
By inject0r in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2012, 13:12 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
Why do I have to Encode?
By gilamran2 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2008, 05:29 -
can't encode on Leopard
By zaouid in forum ffmpegX general discussionReplies: 0Last Post: 19th Dec 2007, 04:15 -
Re-encode to HD
By lotsill in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 12:03
