Hello, any divx tv show I download results in the audio being out of sync when I play them in my dvd player. I am using a Philips dvp 642 player with the lastest firmare. I also unpacked the file using mpeg4modfier.
Is there something I'm missing. Is there any software that can fix the audio problem? Thanks.
Closed Thread
Results 1 to 13 of 13
I don't think anyone will be able to help you much without a GSpot of one of these files. https://forum.videohelp.com/viewtopic.php?t=271697 might assist you with this.
If in doubt, Google it.
Here is a screen shot of gspot. Did I get the right info? How do I fix the audio prob, I have never used gpot before. Thank you for your time.
It's likely MP3 VBR audio is your problem, as it is with many, many, many, videos off the net. Drop it into VirtualDub and extract the audio as a WAV. If you use VD Mod, use jimmalenko's guide: https://forum.videohelp.com/viewtopic.php?t=280779
I've got the feeling we need to make this a sticky.
Must come up about 5 times a week.
I normally use VD Mod, but with VD 1.6:
It's easiest to leave VD open after you extract the WAV, but if not, start it again and select your Divx.
Then under 'Audio', select 'WAV Audio' and point it to the extracted audio, then click 'Full processing mode'.
Now you will see 'Compression' available at the top of the list. Click that. Scroll down the list to 'MPEG Layer-3'. Click that. Select '48k Bit/sec. 24.000 Hz. Stereo'. (Or similar to your original audio. You can check that in 'File'>'File Information'.) Click 'OK'.
Now in 'Video', select 'Direct Stream Copy'. Then in 'File', 'Save as AVI'. Make a new name if you don't want to overwrite you original file just yet.
This will mux (combine) your new CBR audio with your original video and replace the problematic VBR audio and you should be ready to go.
The filesize will be slightly larger as CBR is not as compact as VBR.
If you still have sync problems, then there is some other problem with the audio or video, but this fixes the VBR problem.
It will be worthwhile to learn a little more about VirtualDub. It has a 'thousand' uses.
I use VD Mod as it will accept MPEG video.
Redwudz, I played the Lost episode I tried to fix, but the video played and there was no audio. I now have Vmod 1.5, can you tell me how to merge the wav file with the video? Thank you for your time.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator mats.hogberg
Downloaded TV shows==warez.
Locking this thread.
/Mats
Moderator
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 10:49 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 22:18 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 05:38 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 07:22 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 21:42
