Alright, I've ripped the movie to my HD using AnyDVD (I'm assuming that all the latest protected features have been removed, right?) and now I'm trying to rip the movie file from my HD to DVDR with DVDShrink (once) and DVDClone2 (once).....
Both softwares ran into ERRORs!
the DVDShrink says...
DVD Shrink encountered an error and cannot continue.
Failed to open file "C:\VIDEO_TS\VTS_06_0.VOB"
the DVDClone2 says....
Creation of DVD files was not successful:
Unexpected error
when I click on the Details button, I get this....
NavigationPack 6 32402 121 115 VOBU 4 32402 121 Clone 6 TCE
What's the deal? Was the copy protection not removed by AnyDVD? Help me out gentlemen!
Thanks.
You should have tried right off with CloneDVD2, no need to call up AnyDVD. AnyDVD would have decrypted the movie in the background while CloneDVD wrote to both the HD and DVD. A one step process that should take 20-30 at 8x. Try it again before you start messing with 2 or 3 other pieces of software. Just make sure you "uncheck" the "delete files after burning" box.
I love children, girl children... about 16-40
W.C. Fields -
Did as you've suggested....seem to be working fine thus far! It's in the creating DVD file stage.....when the project is completed, then I'll share the news.Originally Posted by ricoman
Thanks! Hopefully this sucker will work. -
It worked, DVD complete! AnyDVD in the background and DVDClone worked like a charm! Thanks!Originally Posted by ricoman
I had a similar iussue with _Sea of Love_ as a DL 'test'
Run the ND-3550 drives x2. One is 1.04 firmware other is 1.05. 1.05 was 'upset'. The other worked fine. Just an FYI.
kcGiddyup!
Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybe
By Roberht in forum DVD & Blu-ray RecordersReplies: 8Last Post: 6th Jan 2015, 18:02 -
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
DVD to DVDR DL problems
By Martin_S in forum DVD RippingReplies: 14Last Post: 7th May 2008, 20:47 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Philips DVDR 610 Problems
By Rachel85 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Jul 2007, 09:36
