I was under the impression that installing FFDShow, which is supposed to be 'safer' than installing the divx codec, was sufficient to encode an old Laurel and Hardy divx movie to dvd. I've discovered that this is not the case.
Virtualdub also complains that it "couldn't locate decompressor for format DX50 'unknown'".
Use the fourcc changer and change it to DIVX.
/Mats -
Mats,
In the FFDShow 'video encoding configuration' window I did as you advised the but same problem remains.
DIVX Movie Converting?
By RecoveryTTA in forum Newbie / General discussionsReplies: 0Last Post: 22nd Sep 2010, 20:22 -
divx movie with DXSB subs to dvd
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 5th Jul 2010, 14:30 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 10:43 -
How do I convert DVD movie to DIVX w/o Audio Syncs problems
By peggypwr1 in forum Video ConversionReplies: 10Last Post: 1st Aug 2008, 17:22 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
