We're trying to back up a movie with DVD Shrink. Everything goes fine until the burning stage. When the burning commences, we get this error (sorry for all the text):
=== CDRom-Device-Map ===
SONY DVD RW DRU-810A D: CDRom0
HP CD-Writer+ 8200a E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523808kB)
Free physical memory: 155MB (158932kB)
Memory in use : 69 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
2.3.2006
NeroAPI
3:18:31 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
3:18:31 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
3:18:31 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
3:18:31 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
3:18:31 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
3:18:31 PM #6 Text 0 File Writer.cpp, Line 122
Writer SONY DVD RW DRU-810A running
3:18:31 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
3:18:31 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3293
3:18:31 PM #9 Text 0 File Burncd.cpp, Line 3167
Turn on Disc-At-Once, using DVD media
3:19:12 PM #10 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286175 (508:02.25, 4465MB)
3:19:12 PM #11 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO
3:19:12 PM #12 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: SONY DVD RW DRU-810A, Media type: DVD+R
3:19:12 PM #13 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD-R DL, DVD+R DL.)
3:19:12 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286176 (2286176) = #2286176/508:2.26
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286176 blocks [SONY DVD RW DRU-810A]
3:19:12 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [SONY DVD RW DRU-810A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682088448, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286176 | lead-out | 1 | 0x41 | 0x00
3:19:13 PM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
3:19:13 PM #17 Text 0 File Burncd.cpp, Line 4051
Cache writing successful.
3:19:13 PM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
3:19:13 PM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 2.4x (3,324 KB/s)
3:19:13 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:19:13 PM #21 SCSI -1066 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03D10600
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x24 0x00
3:19:13 PM #22 Text 0 File DVDR.cpp, Line 5610
Drive: SONY DVD RW DRU-810A
Book Type request [gen]: DVD-ROM, write to EEPROM
Changing the Book Type was finished successfully, return code 0
3:19:13 PM #23 CDR -1211 File DVDR.cpp, Line 4777
Book Type set to: DVD-ROM
3:19:13 PM #24 Text 0 File DVDPlusRW.cpp, Line 652
Start write address at LBA 0
DVD high compatibility mode: Yes
3:21:47 PM #25 TRANSFER -25 File Reader.cpp, Line 382
Error reading data
3:21:47 PM #26 Text 0 File Reader.cpp, Line 385
Exception value: -1
3:21:48 PM #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
3:21:51 PM #28 Phase 127 File APIProgress.cpp, Line 276
Generating DVD high compatibility borders
3:23:05 PM #29 Phase 129 File APIProgress.cpp, Line 276
Generating DVD borders completed successfully
3:23:05 PM #30 Text 0 File DVDR.cpp, Line 5610
Book Type request [gen]: DVD+R, write to EEPROM
3:23:05 PM #31 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 2.4x (3,324 KB/s)
3:23:05 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
3:23:05 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.1.1.17 , size=24698 bytes, created 7/16/2003 11:19:56 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 11/21/2005 12:48:21 AM
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 11/17/2005 11:19:28 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Can anyone help us out here? Thanks!
Results 1 to 22 of 22
You realise that DVDShrink doesn't actually do the burning - it's Nero, right ?
Perhaps try outputting to an ISO Image and burning with DVDDecrypter.If in doubt, Google it. -
Yes, the error happens when burning with nero. I have also tried DVD Decrypter, and I get the same result. I did a screen shot of the error I will post it.
Thanks<image link edited out - serial # in screen shot> /Mats Moderator -
Sorry, I didn't realize it was showing the number. I am a complete newbie when it comes to this.
Have dvdshrink create an iso file, then burn with dvddecrypter. See if you still get errors. This is how I back up all my dvds now. I no longer use Nero to burn except when creating data disks or audio disks.
Oh yes.....and to burn lightscribe labels (but still not the dvd video)TANSTAAFL -
After you click on Backup, change Backup Target to ISO image.
TANSTAAFL -
The ISO file failed to burn also, I kept a copy of the error message. The error message is a bit long to post. I am out of ideas.
I noticed the burn speed is set at 2.4x,is this the max speed of the media?If so try 4x or 8x media.
Also use Nero InfoTool to make sure DMA is enabled.
If different media doesn't help then your writer might be fried. -
Iv'e tried different burn speeds, 2 new burners, etc. I don't know about the DMA being enabled. Were do I check that at? Where in info tool do I look?
Thanks for taking the time to reply.
It might just be the DVD I am trying to copy, who knows. -
Try to update your firmware. I had a strange error on my NEC DVD drive where it just refused to write to some Fuji DVD+R DL discs despite having written to these discs earlier. As best I can tell, something on the discs changed and it took a firmware upgrade to get the DVD writer to be able to write to the discs. I can't guarantee this will fix your problem, but you can try.
If DMA is not enabled on all your drives then read how to enable in my sig below.
To check latest firmware go here: www.rpc1.org -
I looked at Nero InfoTool, I checked the DMA and their all set to on. My firmware version is 1.0a. I happen to click on the ASPI tab and at the bottom in red it says, ASPI installation is corrupted.
Does anyone know of a free program that will convert avi to mpeg2?
Use ForceAspi Drivers to fix a bad ASPI layer and most encoders have a 30 day trial.
Originally Posted by Baldrick
I tried these they didn't work. Is avi and divx the same thing? I believe they are divx files I am trying to convert. They have a .avi extension. Any ideas?
Thanks again, you guys are lots of help, I appreciate it.
Dvd Shrink Gives me and error?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 12th Jun 2010, 19:05 -
DVD Shrink 3.2 .IFO Error
By michpearl in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2010, 23:02 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
dvd shrink reauthor error
By victoriabears in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2010, 15:09 -
Error when trying to shrink DVD files
By bambam in forum DVD RippingReplies: 10Last Post: 9th Jul 2007, 11:54
