Here's the deal, I have some vob files, Wrestling to be precise.
And i wanted to convert them to the HIGHEST quality 352x240 mpeg1 file, i use tmpgenc and mainconcept most of the time. the problem is i cant get the quality to be as good as others encode's, when i encode the file i use like 3000CBR and dont get high quality results. All i really want is for a sharp good quality mpeg 1 file, if you have any idea's on how to convert to full quality mpeg1 files please share your idea's. thanks.
BTW the vobs are from a dvd source.
You would be better off doing MPEG-2 at 352x480
The "optimal" bitrate would be a CBR of 4000kbps to 5000kbps but 3000kbps should look OK especially if you do a 2-pass or multi-pass VBR encode. In that case I would suggest a MIN of 1000kbps, an AVG of 3000kbps and a MAX of 5000kbps. For the audio use 192kbps AC-3 format.
If you intend to burn the results to a DVD the above 3000kbps video with 192kbps AC-3 audio will give you just over 3 hours per single layer DVD.
Quality came out crap again
how do i put the vob into tmpg? virtualdub,dvd2avi?
DVDRipper12, if you must have an Mpeg1 file then...
Mpeg1 files are not limited to 352x240. You can use 640/704/720 x 480 and use a bitrate of at least 2Kbs.
Use VirtualDubMpeg2 to convert the VOB to DV AVI with the Panasonic DV Codec or frame serve to TMPGEnc.
Set up TMPGEnc to encode a Mpeg1 file at XX0/480, 2.5Kbs.
Regards,
Chas -
Some thing must be wrong...as a mpeg1 of 352x240 at a VBR over 2000 kbs should be very clear. I have over 100 mpeg1 movies at under 1000 that look great. check out this guide...
https://www.videohelp.com/sefy/?id=ClassicalGuide.html
it is one of the originals from when I started making VCDs. With out giving us more info...you'll have to try and see where you are going wrong. Basic steps: Rip DVD(smartripper)> Make a d2v and wav from VOBs using DVD2AVI (so that TMPGenc can read the VOBs) >Encode to mpeg1 or 2 using TMPGenc. -
Thanks alot for the help guy's, the panasonic dv codec and DGIndex done it
VOB conversion help
By MarkL1986 in forum Video ConversionReplies: 4Last Post: 14th Feb 2011, 09:10 -
.vob to .flv conversion
By mayur in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2010, 08:04 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
VOB to DV conversion
By candy56 in forum ffmpegX general discussionReplies: 12Last Post: 28th Dec 2009, 23:53 -
.vob Editing/Conversion
By matedog in forum Video ConversionReplies: 2Last Post: 13th Dec 2009, 11:27
