Results 1 to 9 of 9
  1. vcd
    8-9 hourrs ripping a 1:30movies
    with tmpgenc
    750 duron
    384mbram
    pioneer 16X
    $an
  2. Ok, right now, i am ripping one for the first time, (ha ha) and it is only taking me as long as the movie is (rush hour 2 - funny movie) which is like 2 hours!
  3. what spec and software r u using ?
    because it took me 8 hours to encode rush hour 2
    $an
  4. Athlon 1.2
    256 Mb Crucial
    XP Prof
    Am using TMPGEnc
    Feb 2001
    Palmdale, CA
    your encoding time is about right for your cpu, to get close or better than real time you will have to upgrade to a P4 1.5 or better, or an AMD 1600+xp or better.
  6. for the last time, RAM DOESN'T AFFECT ENCODING TIME.
    encoding for 2 hr movie:
    650 mhtz athlon non t-bird: ~14 hrs
    1.2 ghtz athlon t-bird: ~6 hrs
  7. What if I'm running 4 megs on a 200 mhz PII, 10 gig HD, with Win 95c?
  8. Banned
    Apr 2001
    Calgary, Canada
    hehehe here here
    My NTSC VCD's...
    22 mins of a TVCap on a P3-550... 4 hours 6 mins.
    22 mins of a TVCap on a P3-964... 2 hours 17 mins.
    (512MB PC133 CAS-2 RAM and dual IBM 60gig 7200rpm drives)
    Using:
    VirtualDub 1.4.8 frameserving to...
    - Direct stream copy (a&v)
    TMPGEnc 2.02
    - Noise Reduction (High Quality)
    - Soften Block Noise @ 35/35
    I don't remember how long DVD rips take... Though I never use any filters on them.
    <font size=-1>[ This Message was edited by: HillJack on 2001-12-31 12:54:23 ]</font>
  9. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    heh....ok..i meant normal about of RAM...RAM only matters if you wanna do multiple applications at once...however, i highly doubt people will run another proggie while encoding.
    btw....first post is for SVCD encoding by tmpgenc CQ_VBR with CQ=70 max bitrate=2520 high quality (slow) motion search accuracy and no filters.
