  1. My bro-in-law sent me an ISO image of a home movie I am trying to burn to a DL DVD.
    The said file is 7.69GB.
    Using Nero, I select "Burn Disk Image" and get the following error...
    Session fixation error
    Could not perform end of Disc-at-once
    Burn process failed at 2.4x
    Using Decrypter I get an I/O error saying...
    ScsiStatus: 0x02
    Interpretation: Check Condition
    CDB: 2A 00 00 00 00 00 00 00 20 00
    Interpretation: Write (10) - Sectors: 0-31
    Sense Area: 70 00 03 00 00 00 00 12 00 00 00 00 73 02 00 00 00 0000 01 02 03 04 05
    Interpretation: Power Calibration Area Is Full
    Decrypter says I have enough room on the disc and recognizes the DL disc, but I can't get it to work.
    I have tried ISOBuster and saved the DVD files to my HD, then burn the DVD files as I always do, still no dice. I have even tried to convert the files using Nero to fit on a DVD+R (regular 4.7GB).
    I have a HP DVD640i and I know it is DL compatiable....and I am using Verbatim DL discs.
    I have been working on this for weeks and can't figure it out, I am not exactly a newbie when it comes to all this, but I am stumpped...please help.
    TIA.
  2. Banned
    Feb 2005
    USA
    There are usually only two reasons for Power Calibration errors if the drive is still functional. One is bad media(which Verbatim isn't) and two is a dirty laser lens. I'm going to suspect the lens can not calibrate properly for dual layer burning because it is dirty.
  3. never cleaned a lens...I guess just buy a lens cleaning disc?
  4. Took the drive out and cleaned it throughly, still no luck...still getting error messages.
