    Mar 2006
    could someone please help me!!!!! i am looking for software or a program, where i can change the faces of a person in video mode....can someone please point me in the right direction....i have adobe photoshop...but all i can do is change photos...any help with this would be greatly appreciated....thank you in advance
  2. Member Sartori's Avatar
    Nov 2002
    Do u mean smear the video to provide anonimity ? or do you wish to morph a persons face to something else ? if you wish to smear a face , then I seem to recall a filter for virtualdub that can do it , any movement will need to be manually set as the video progresses .
  3. Member dipstick's Avatar
    Jan 2005
    Dark side of the Moon
    WinMorph
    I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
    Apr 2004
    Miskatonic U
    How much effort do you want to go to ? Is it just pasting a still over the face, or changing it for a video ? Is the head to be replaced still or moving around in the frame ?
    Read my blog here.
    Mar 2006
    what i would like to do is....change the face on a small sexy clip to someone like say paris hilton.. or some other celebrity....i actually have a sample of what i would like to do...here it is..hope i dont get banned from this forum...i have appreciated the help....
    http://rapidshare.de/files/1059968/Computer_Made_Fake_Porn_Celebrity_Fuckfest_vol_4.avi.html
  6. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    To start off with that isn't easy... First you have to find two clips that are similar, where the heads are in similar positons. A clip of the person you want to put on the base video with a solid background would be ideal, if the person you want to put on the base is available all the easier as you can manipulate your footage.
    Basically you take footage A (with the person you want to add) and ovelay it on footage B. This is where the solid background comes in, if you have a solid background better editors can auromatically remove this, otherwise you would have to remove it by creating a mask and key framing it throughout the video... as I said this not easy and would require a book to explain.
    The better editors have this ability, either Vegas, Premeire or Media Studio Pro. On the low end Ulead VS will do the background removal but I don't know to what degree you can manipulate the footage afterwards.
    I'd suggest trying it with a image editor first on single image and you'll see what you are dealing with. Even doing single images and making them look half decent can be hard.
