  1. I can get a sample for anyone who wants one...but every movie i get and convert, there is a pink shading to most areas on the screen...gradually getting worse and worse, then it disappears, repeating this throughout the movie...
    Anyone know if there is a fix for this?
    This is on most new ripped movies (TMD avi files etc)
    TIA!
    ross
    Nov 2000
    Thunder Bay, Ontario Canada
    I also had this problem when I upgraded to a beta copy of windows xp on the same type of movies you are talking about, it does not happen on dvd rips tho, why this is i have no clue, what I did to fix the problem was go back to 98. If you do have xp I have heard of a patch somewhere that can correct this, but I coulnd give you a link for it, it may also help to upgrade to the final if you are using a beta copy.
    Good Luck!
  3. nope, using w98 SE...
    Nov 2000
    hmmmmm, interesting.... I went back to 98 fe but if it was an error in the os it would carry between 98 se and xp beta, all i can say is try updating/changing your divx drivers, Os. One thing i did remember that made the pink crap go away is if you used the old windows media player included in morpheus/kazaa. For some reason it was the only proggy that could read the movies properly for me, playa, vdub and tmpg all showed up with pink stuff.
    See my post where I had this problem and no one cared
    https://www.videohelp.com/phpBB/viewtopic.php?topic=60650&forum=5
  5. Yeah, it might be a divx codec problem...but even wen i convert with tmpgenc or whatever...still shows up...
    can i send you a small clip and see if you see the red too? if you dont, maybe you could send me your codec and maybe that would fix it?
    Ross
    gimme an email and I can setup my ftp server for ya!
    Nov 2000
