last nite my Internet Explorer on my Win2K machine started acting weird.
I first noticed it on the Netflix site. Every time I would try to click on a title's "Add" button, IE would pop up an error dialog saying that IE had experienced a problem and needed to close.
Every single time I clicked the "Add" button....
I figured it was just a temporary problem with that site and moved on to some other surfing.
but it was happening at other sites as well.
when I try to access my work email from home, as soon as the secure site comes up it gives me the same message
some forums cause it when I click on the button to reply to a thread.
if there's a pattern to the problem, I'm not seeing it...
I went to MicroSoft's site and downloaded the latest service pack and update for IE, but the problem persists.
Any clues as to what the problem is?
I tried back-tracking to see if there had been any changes to my system since the time IE was working properly (only a few hours before). No new or uninstalled programs. Ran a full virus and Ad-Aware scan, no problems. no new hardware.....
I couldn't find just a basic installation file for IE on the MS site...
I'm thinking of using the Add/Remove programs app to simply delete IE and then re-install it from the Win2K install disc.
What files would I need to back up first?
any insight would be appreciated, but please no fan-boy rants.
I've tried Opera, FireFox, Netscape, and all the others -- I don't like them.
I'll stick with IE.
TIA!!
Results 1 to 13 of 13
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
About the only thing I backup are the 'Favorites'. Most everything else will replace itself. I don't keep the cookies unless I have cleaned out the ones I don't want.
I'm not sure how well you can uninstall IE as it is pretty tightly integrated with the system.
I assume you have tried to reset IE to 'default' settings?
You could go to MS and see if there is a troubleshooter or help or error page for IE, but the crash seems generic, and if random, not so easy to pinpoint.
While you are at MS, you might do a search for 'reinstalling (Or uninstalling) IE'. -
You can try:
1) download i/e setup file from here:
http://www.microsoft.com/windows/ie/downloads/critical/ie6sp1/default.mspx
2) follow this procedure to install:
http://www.tacktech.com/display.cfm?ttid=176
Have you tried a repair reinstall of windows 2000?
You can also try 2000Lite from here which will let you uninstall and reinstall I/E using your existing system install disk. I use XPLite myself (No trace of I/E on my system). I think they have a freeware version and pay version.
http://www.litepc.com/xplite.html -
It could be a BHO (Browser Helper Object) that is interfering with normal functionality. BHOs are frequently used by spyware/malware to create plugins for internet explorer. Many times, these plugins interfere or slow it down considerably. Try using HijackThis, and remove any BHOs that exist.
hhmmmm...
i did get a nasty bit of malware earlier this week.
it was a bitch and disabled regedit and task manager!
it took me 2 hours to clean the shit up and get rid of it."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
i had a friend IE6 would shut down everytime he tried to open another window or click on a link. he installed the yahoo tool bar which is a BHO(browser help object). when he unistalled the tool bar everything started to work again. one way around it for him was to hold down the CTRl button before clicking on a link. he got tired of holding down the button to click on a link
I'd considered that too.
I still have the "java" that came with IE5...
I downloaded the newest from Java, but the installation fails everytime I try to run it -- it never tells me why though."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
nope didn't have to install anything.
Norton has autoprotect -- I've been running it pretty much non-stop for years."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
I had a similar problem onetime and i ran ie fix http://windowsxp.mvps.org/utils/IEFix.zip and it got everything back to working order.
3rd party add-ons malware or otherwise can mess with ie, some major offenders are toolbars, search helpers, optimizers, accelerators, download managers etc.
which is why I have none of those silly-ass add-ins.
my security settings are fairly restrictive as well -- most folks hate trying to surf on my machine because of it."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
