I'm using the Pocket HDTV from http://www.inventa.com.au. It's a nice looking slimline, external tuner, but I'm having a few issues. The MPGs I save play jerkily on most viewers and video editors. I wondered is this was common with TV tuners? I can't use the MPGs with my video editor (VideoCharge) and instead have to resave them as MPGs with some other software I found, before they will work with VideoCharge.
The device comes with a BDA driver, which the manual says should allow it to work with other TV software. I tried getting it to work with Meedio and TV Plus 4 Gold, but neither recognised the device.
The bundled software is ok, but it has some nuisance bugs and crashes every so often. I also find the reception is sometimes glitchy, which seems to coincide with the most simple of things such as moving the mouse around. I'm using a Pentium M 1.7Ghz laptop which should be ok.
I read it's common for TV tuners to sometimes only work with the bundled software, but what about the rest, like the MPG playback problems and the reception glitches?
If I get a refund, what would you recommend as a mid-level USB digital TV tuner, that's also travel sized and stylish?
Jason
Results 1 to 1 of 1
Problems playing recorded .mp4 files
By dhr3 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 14:17 -
Demuxing HDTV .ts recorded in DVB-TH tuner - help
By newstrength in forum DVB / IPTVReplies: 7Last Post: 2nd Jun 2010, 14:34 -
having problems with a dvd i recorded
By bigv1385 in forum MediaReplies: 1Last Post: 23rd Apr 2010, 14:58 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 08:57
