    Mar 2006
    Recently a friend in Germany sent me some DVD's that he created with what he calls a "code free" recorder. I tried them in my Sony RDR GX-315 and got an error message on the screen that says the disc is neither playable or recordable and then the machine ejects the disc. I also tried them in a friend's Panasonic DMR-ES20S and they would not play either.
    Next I tried to play them with my PC. Windows Media Player shows the menu page, but will not play the video part at all. I then tried InterVideo Win DVD5 which is also installed on my PC and they played fine.
    I then tried them in my brother's inexpensive Zenith DVD player and they play fine.
    Why do they play on the cheapo Zenith player but not on the Sony ? Is it just the machine itself ??? Format ??? I've played other discs in the Sony that were created on other machines and PC's with no problems. Thanks.
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I would guess its more to do with NTSC and PAL issue than a Region issue. Germany is in PAL region, and as you are located in the USA, you're in NTSC. You would need a dvd player/tv that plays PAL. PCs dont care about NTSC/PAL which is why you could play it wth WinDVD.
    You could convert the DVD from PAL to NTSC. Check out some guides on the left.
