I've got a mpeg-4 movie file with dutch subs (selectable no permanent). I'd like to remove them ( i mean the stream) and add some other language subs. Is it possible? How should I do it? What program should i use? Any help would be highly appreciated. thanks in advance. joe
Results 1 to 9 of 9
You mean an mp4 with ttext subs, an mp4 with vobsubs, an avi with srt subs, a divx file with xsubs or what?
Thanks celtic for your fast answer, didn't answer cos i had to leave. I meant pm4 con ttext sub. Been fooling around with nero recode but guess nero doesn't do the job or i don't know how to. I'm not an expert but i know some basics (I've authored some dvds) but this mp4 format is new to me. Thanks for your answer again cos there isn't much help about subtitle topics. joe
Hi, baldrick I tried yamb but i coundnt find the way to elimanate the sub stream, so what i did was to try to add the other sub in the mux tab, but i got the following error while muxing:
btw the subs were in srt format, is that ok?
IsoMedia import - track ID 1 - media type "odsm:mp4s"
IsoMedia import - track ID 2 - media type "sdsm:mp4s"
IsoMedia import - track ID 3 - Video (size 336 x 256)
IsoMedia import - track ID 4 - Audio (SR 48000 - 2 channels)
Invalid IsoMedia Media
This is the file info:
* Movie Info *
Timescale 1000 - Duration 00:40:50.200
Fragmented File no - 5 track(s)
File Brand mp41 - version 0
Created: Thu Jun 30 02:59:57 2005
File has root IOD
Scene PL 0x01 - Graphics PL 0xfe - OD PL 0xfe
Visual PL: Simple Profile @ Level 0 (0x08)
Audio PL: Main Audio Profile @ Level 2 (0x02)
Chapters:
Chapter #1 - 00:00:00.000 - "Chapter 1"
Chapter #2 - 00:02:43.200 - "Chapter 2"
Chapter #3 - 00:05:25.600 - "Chapter 3"
Chapter #4 - 00:07:42.120 - "Chapter 4"
Chapter #5 - 00:11:25.960 - "Chapter 5"
Chapter #6 - 00:14:09.520 - "Chapter 6"
Chapter #7 - 00:18:00.600 - "Chapter 7"
Chapter #8 - 00:20:25.840 - "Chapter 8"
Chapter #9 - 00:21:30.000 - "Chapter 9"
Chapter #10 - 00:27:11.960 - "Chapter 10"
Chapter #11 - 00:29:40.360 - "Chapter 11"
Chapter #12 - 00:32:38.280 - "Chapter 12"
Chapter #13 - 00:36:16.200 - "Chapter 13"
Chapter #14 - 00:37:24.200 - "Chapter 14"
Chapter #15 - 00:40:09.040 - "Chapter 15"
Track # 1 Info - TrackID 1 - TimeScale 1000 - Duration 00:00:00.001
Track is present in Root OD
Media Info: Language "eng" - Type "odsm" - Sub Type "mp4s" - 1 samples
MPEG-4 Config: ObjectDescriptor Stream - ObjectTypeIndication 0x01
Self-synchronized
Track # 2 Info - TrackID 2 - TimeScale 1000 - Duration 00:00:00.001
Media Info: Language "eng" - Type "sdsm" - Sub Type "mp4s" - 1 samples
MPEG-4 Config: SceneDescription Stream - ObjectTypeIndication 0x01
BIFS Scene description - Command stream
Synchronized on stream 1
Track # 3 Info - TrackID 3 - TimeScale 25000 - Duration 00:40:50.200
Media Info: Language "eng" - Type "vide" - Sub Type "mp4v" - 61255 samples
MPEG-4 Config: Visual Stream - ObjectTypeIndication 0x20
MPEG-4 Visual Size 336 x 256 - Simple Profile @ Level 0
Pixel Aspect Ratio 1:1 - Indicated track size 336 x 256
Track # 4 Info - TrackID 4 - TimeScale 48000 - Duration 00:40:50.176
Media Info: Language "eng" - Type "soun" - Sub Type "mp4a" - 114852 samples
MPEG-4 Config: Audio Stream - ObjectTypeIndication 0x40
MPEG-4 Audio AAC LC - 2 Channel(s) - SampleRate 48000
Track # 5 Info - TrackID 5 - TimeScale 90000 - Duration 00:40:46.480
Media Info: Language "dut" - Type "subp" - Sub Type "mp4s" - 438 samples
MPEG-4 Config: Unknown (0x38) Stream - ObjectTypeIndication 0xe0
Any ideas? Thanks! -
|bond|, tarzan1990 thanks for your help!!! mp4ui worked like a charm
gonna try mp4creator anyway.
How Can I Remove the Subtitles from a .VOB File and a .AVI File?
By channelz28 in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2011, 19:45 -
how to remove subs embedded with all to avi
By pike8 in forum Newbie / General discussionsReplies: 3Last Post: 24th Feb 2009, 11:42 -
Remove ads, subs and audio that I don't need and modify buttons
By Brent.M in forum DVD RippingReplies: 8Last Post: 13th Aug 2008, 10:38 -
Batch remove audio/subs
By BVT in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2008, 12:58 -
Remove subtitle track from mpeg-2
By ehogan in forum MacReplies: 1Last Post: 25th Jan 2008, 20:05
