  1. I ripped the dvd using dvd decrypter in "file mode" not IFO. so i have a bunch of vob files. i loaded these up in autogk and my final product is horribly out of sync with the audio. i am thinking it is because i did it in file mode, but i wouldn't see why taht would matter. i thinking about adding all of the .vob files in vStrip to create one .vob. maybe the audio willl stay in cue if i do this? anyhelp would be good - thanks
    Mark
    USA
    If you just wanted one large VOB with Decrypter: 'Tools>Settings>File Mode>File Splitting' and set it to 'None'.
    Jun 2005
    Portugal
    Do as Redwuds said : RIP to a huge an single VOB file
    AND DO IT in IFO MODE
    And I don't know if autogk manages to check delays of audio when demuxing the VOB file
    I use ProjecX to demux the VOB, and it syncs audio and video automatically, don't have to care about delays
    And then DGIndex + Nabdub
  4. hey - thanks for the help. but i no longer have the dvds, my friend is borrowing them, so the only files i have are the 4 or 5 vobs files (ripped in file mode).. if i load these in for demuxing hopefully that will solve my audio sync problem? i don't know..........
  5. Originally Posted by Mark6677
    Try using DVD2MPG to combine the VOB's into a single MPG file. Open it on your PC to make sure the audio is in sync, then try running it through AutoGK. See if that helps.
  6. Tried using DVD2MPG and an error message came up at the beginning - the program closed a couple times while i was in the middle of my conversion. it frustrated me and so here i am again.... i think that the program i need to use is vstrip. what is a good program to use to view my .vob file after vstrip has processed it? my final goal is to get 1 .vob file and import it into autogk then let it do the rest....
  7. Originally Posted by Mark6677
    Mark
    Assuming that the total size of the VOB files are less than 4.7 GB, burn a DVD movie on rewritable media. Then use DVD Decrypter to rip it in IFO mode.
  8. I would do this, but i ripped 5 of my movies; so i'm not too thrilled about doing this with all of them. I used Vstrip to make 1 .vob file from all of my original vobs. i loaded this into agk and it is very close to being complete - i do hope that it works. I just don't see what the huge difference is between ifo and file mode when ripping through dvd decypter. the resulting files are exactly the same..
