I extracted a huge AVI from a bunch of RAR files. But when it's played, it has no sound. I'd like to how to check whether the AVI itself has audio and what I can do in order to play its audio?
Results 1 to 9 of 9
Most likely your AVI file has no audio, since FAR compression should not to affect a stream.Originally Posted by funnybunny
But if you are familar with GraphEdit just render your file there(File->Render Media File) and take a glance at AVI Splitter if it has audio output pin.
If an AVI nevertheless has an audio you can try to remux your file to force an audio to be played (https://forum.videohelp.com/viewtopic.php?p=1472491#1472491)my AVI Trimming guide
https://www.videohelp.com/forum/viewtopic.php?t=283241 -
I'm sure it has audio - but your computer hasn't got the codec to decode it. As thecoalman suggests, try GSpot. It will tell you what audio codec is used (my guess is AC3) and you can then download the codec needed.
/Mats -
I think my AVI has audio, when I played it w/ WMP, it shows the audio stream's playing. I tried GSpot, here's what I got:
Code:container OpenDML (AVI v2.0) DivX Style "packed bitstream" AVI Interleave: 1 vid frame (40ms), preload=512 Audio frames: Split across interleaves File Length Correct User Data/Metadata (ISFT) Nandub v.1.0rc2 (JUNK) Nandub build 1852 (JUNK) release (USER) DivX503b1393p (USER)Xvid0039 (USER) Divx503b1393p Audio Codec: 0x2000(AC3, Dolby Laboratories, Inc) AC3 Stat: Codec(s) Installed Info: 48000Hz 192 kb/s total (2 chnls) Proposed Codec Solutions and Tests GSpot Aud button 2: (Src)--->>--(A)--->[AVI Splitter]>---(B)-->[AC3Filter]>-->(C)-->[Default DirectSound Device] Audio Render OK. Use [3] to play. (Src)--->>--(A)--->[AVI Splitter]>---(B)-->[ffshow Audio Decoder]--(C)-->[Default DirectSound Device] Audio Render OK. Use [3] to play. (Src)--->>--(A)--->[AVI Splitter]>---(B)-->[CyberLink Audio Decoder]--(C)-->[Default DirectSound Device] Failed to connect Output pin 0x009c9c0c ("Stream 01") on AVI Splitter to input pin 0x009cd75c ("Audio In") on filter 0x02151970 ("CyberLink Aduio Decoder").ConnectDirect()failed. Error0x80040207: There is no common media type between these pins. (Src)--->>--(A)--->[AVI Splitter]>---(B)-->[Nero Digital Audio Decoder]--(C)-->[Default DirectSound Device] Failed to connect Output pin 0x009c97fc ("Stream 01") on AVI Splitter to input pin 0x009ce42c ("Digital Audio In") on filter 0x02174432("Nero Digital Aduio Decoder").ConnectDirect()failed. Error0x80040207: There is no common media type between these pins.
That line
is your answer as mats.hogberg suggested.Codec: 0x2000(AC3, Dolby Laboratories, Inc) AC3
Try AC3 Filter. -
I already installed the latest K-lite codec pack, and it contains AC3 filter. but the AVI still couldnt play sound. When I tried to open that AC3 filter, a window pops up saying, "This utility is for OFFLINE filter configuration only! this means that you will not see any activity of currently playing applications and configuration setting will not affect them. you;ll need to restart you player for changes take in effect!" So does that mean that I need to installed another AC3 filter separately?
Installing a codec pack is a big mistake. They cause much more problems than they cure. Do a forum search for 'codec packs' and you will see why.
AC3 filter works fine for me. You may have a codec conflict.
Try VLC Media Player. It has it's own codecs. -
VLC MEDIA PLAYER solved the problem. a frd of mine told me to adjust the audio switcher in WMP's options, but I couldn't find it in its options. Then I saw the Audio menu in VLC media player. I adjust the audio channnel into reverse stereo, it works!!!
AVI - No sound on PS3
By tehkimsta in forum AudioReplies: 2Last Post: 14th Apr 2011, 21:48 -
Vob to avi, NO SOUND
By pekkaaa in forum ffmpegX general discussionReplies: 1Last Post: 24th Dec 2009, 13:10 -
.mov to .avi with sound
By siobhan in forum ffmpegX general discussionReplies: 2Last Post: 2nd Jul 2008, 01:25 -
no sound for avi
By kangaris in forum EditingReplies: 5Last Post: 22nd Sep 2007, 07:26 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21
