  1. Member b1tchm4gn3t's Avatar
    Nov 2003
    Illinois, USA
    If anyone has any experience with a wireless router going through a couple of block walls and a half a block away PLEASE let me know what you have and where I can get it at. Basically I need a wireless setup to do just that. I dont mind getting a cheap repeater antenna if need be (if they even make something like that). Thanks.
    If at first you don't succeed; call it version 1.0
  2. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    What We Do In Life, Echoes In Eternity....
  3. your link for the electrical outlet thing is broken.....
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Netgear Wall Plugged Ethernet Bridge, model XE102
    Netgear model WGXB102 wall plugged wireless range extender
    I haven't researched them to tell you what the differences are......
  5. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Although the WRT54G is one of the best routers (I have one), he said he need something with power to go through walls and a long distance. I have tried to run a wireless network with my wrt54g to the other side of my house (200+ft away) and no luck. Not even with the range extender. That's why I listed the Linksys SRX400 Router(more powerful I have heard)
    From the http://www.linksysinfo.org/ website, "SRX400 MIMO technology that boasts 10x the speed of standard 802.11g and over 3 times the range"
  6. Banned
    Feb 2005
    USA
    The thing I have found with Wireless routers is to never buy a router without either removeable antennas or an external antenna jack. If you have to reach extended distances or have significant structural barriers make sure to set aside enough money for a high gain antenna. Range extenders are only as good as the antenna they are receiving from. Most standard stock wi-fi antennas on routers are low grade junk(to put it mildly). It may work for your particular network, but the same antenna in another network will be crippled.
  7. Member b1tchm4gn3t's Avatar
    Nov 2003
    Illinois, USA
    ps. if there is something that can be mounted on a roof that would work for me too.
