Hello, I'm really a newbie, and before going any further, I want to know if it's possible to select the language of the film I'm ripping. I went through this method (Sefys classical newbie start DVD Ripping guide) But I didn't see any place for the language.
Thanks,
<font size=-1>[ This Message was edited by: Epocaster on 2001-12-30 18:22:28 ]</font>
To select a diffrent Audio Track you need to tell DVD2AVI which track you want, if you used Smart Ripper to rip the movie, you can check the Info Text File for knowing where each Language is located, and then change the track accordingly.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
How to remove the language selection menu from BR Disc
By The-One in forum Authoring (Blu-ray)Replies: 21Last Post: 27th Apr 2014, 16:00 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
XP OS selection at startup.....
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2009, 00:55 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29
