Captured with a Conexant C2388x chip, NTSC, 720x480, S-Video in, Digital Cable box source (MPEG-2 TS -> NTSC). Problem occurs regardless of capture software used.
Large splashes of orange color have vertical bands.
Lettering has blocks around the edges.
In the last shot, things seem fine (from the exact same source, no settings changed).
Any ideas what's going on?
Other images available if needed.
(Click for big)
Results 1 to 9 of 9
Have you checked the cable connection into your cable box. It looks like it might be a bad signal at that point You may have to disconnect and reconnect the cable line or maybe check if it is tight.
Can anyone comment a little about it?Originally Posted by RS VP
I refuse to believe my card is bugged. -
That looks like something is not connecting properly. Make sure the cables and the card itself sits tight.
I believe everything is connected properly. I can't make samples for now, my video card is bugged, but I'll make it next week.
I didn't say you had a bugged card I said it a bad card mean there something wrong with one of the part on the card it self I only scean one other perason with all most very same problem.I refuse to believe my card is bugged.
Here screen of his problem about 6 months back
RS VP:
You didn't define your set-up too well. But this kind of distortion usually boils down to two things: electronic interference or a bad capture device. Are you running your equipment on a battery backup with a voltage regulator? Do you use shielded (Monster, preferably) cables? Are you lining the cable feed through any other device before it gets to your capture card? Is any type of heavy appliance running on the same circuit breaker as your equipment?
Try to look at those causes, then narrow down to the device. Post back any results/queries.
Something weird is happening here...
By montreal in forum ComputerReplies: 4Last Post: 21st Dec 2011, 16:23 -
LFE audio samples, are there any samples to download and try
By wetduck in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2011, 10:17 -
.MOV to FLV not happening
By makman in forum ffmpegX general discussionReplies: 4Last Post: 21st Jul 2008, 16:48 -
Weird stuff happening. Help
By tim_ver in forum Newbie / General discussionsReplies: 14Last Post: 18th Oct 2007, 18:53 -
Traffic shaping on YouTube - is it happening elsewhere?
By Midzuki in forum Off topicReplies: 2Last Post: 20th Aug 2007, 19:03
