i've tried every method i can stumble upon to convert this dvd to divx, however the conversion always ends up glitchty at certain points (i.e the video will go back a few frames, ect) and yes, i checked the disc out, it's not scratched to the point where it should be doing this....i think it may have something to do with the "follow the white rabbit" special feature included in the disc....just curious if anyone's been able to properly convert this dvd, and if so, how? I've already tried fairuse wizard, i've also given a stab at the "manual" methods....i.e. loading vobs into DGIndex, outputting a d2v file, ect......i noticed in fairuse wizard that the dvd has 2 video streams, i tried to convert both streams and ended up with identical results both times....
Might try isolating one title using shrink to reauthor (with no compression) or checking other threads for ways to do the same thing in decryptor.
In DGIndex might double check, experiment with pulldown settings, rendering short test (including prob scene) to avi. Make sure field order isn't scrambled/reversed. And might try unchecking the box in DGIndex for correct fields. -
i'll give the dvdshrink method a run, it didn't really cross my mind.....i know it's not the other things you mentioned though, field order, ect........because basically the movie will play fine throughout then when it hits a proplematic part of the video, the video pixilates and goes back like a half second.....it's more of an annoyance than anything....
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 08:12 -
sync issues with DVD to DivX conversion
By snafubaby in forum DVD RippingReplies: 12Last Post: 24th Dec 2008, 02:10 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 19:21 -
Best conversion method for mass DVD to DivX
By spidey in forum Video ConversionReplies: 3Last Post: 1st May 2008, 08:29 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 04:13
