Ok, Ive converted an MKV file to a M2V and Ive demuxed the DTS file from the MKV and downmixed that to a Dolby 2.0 file (for DVD specs).
But Ive brought these into DVD Lab Pro and Im getting different run times for each one of the audios. Why is this? I have done no editing of any kind, simply demuxed and converted. Whats the problem?
Ive had simlar problems where I have converted a Wave to AC3, and imported this into DVD Lab, and the AC3 has been a few seconds shorter/longer (I dont remember which) than the video but upon compiling there has been no audio sync isses. Is this just the same problem, but it seem to be more out of sync due to the sheer length?
Ive spent so long on this, I'd hate to see it all screw up now.[/img]
Does the rendered DVD layout play OK on your HD? If so don't worry about it.
If you got the ac3 from the dts pictured, generally should be the same length -- might want to double check lengths during your DTS -> AC3 conversion to determine where in the process the change occurs, but again, if it plays OK on your HD don't bother. -
Well Ive checked and it plays more or less in sync. If theres any correlation between image and sound, the sync must be mere milliseconds in length. Then again, I think that itself is just due to the fact I need a reboot!
I guess DVD Lab guestimates wrongly, it seems OK.
Case closed.
mkv audio sync issues
By Bloodnut05 in forum Newbie / General discussionsReplies: 5Last Post: 15th Sep 2011, 04:06 -
audio sync issues after converting mkv to iso and burning to bd-r/dl disc..
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 15:03 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 06:56 -
Audio Sync issues under Vista 64 and H264/AC3 MKV files at 1080p
By tarrantm in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 21:56 -
MKV to DVD Sync Issues
By snadge in forum Newbie / General discussionsReplies: 0Last Post: 13th Jan 2008, 08:12
