Results 1 to 13 of 13
  1. When I encode an AVI to DVD mpeg and try to play it with WMP it won't play, PC freezes and i have to reboot.
    but they will play with VLC.
    GSpot can find the audio codecs for it but not the Video.
    any ideas?
    install a mpeg2 codec like Dscaler MPEG Filters or powerdvd,windvd
  3. already had powerddvd, installed Dscaler and same problem.
    also noticed (before i installed Dscaler) when i exit VLC ram goes down from a GB to 230 MB!? also cpu at 60% this lasts a couple of mins then returns to normal.
    EDIT. WMP playing the encoded mpeg but it takes about 3mins to load.
    have no other proplems on PC except this.
  4. EDIT (had too much THCs) it is only encoded mpegs giving me problems and the only thing that plays them properly is TMPGENC Author.
  5. can get the encoded mpeg to play with windvd. thanks Baldrick but can you explain why some apps play it but others crash?
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Some apps (like PowerDVD, VLC and obviously windvd) use their own codecs, while WMP and others use DirectShow to decode the a/v. If DirectShow (part of Windows) is f*cked up, all apps that uses DirectShow will appear to fail, where it's actually some part of DirectShow that's having troubles.
    /Mats
  7. i was getting end program activemovie window which was old name for directshow, but i've got XP.
    so obvious question is how do i repair it?
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Installed any codec packs? Theyt tend to wreak havoc with Directshow. There's utilities like CodecSniper to remove unwanted/troublesome codecs.
    /Mats
  9. no codec packs, I've been on here long enogh to know to avoid them lol
    tried codec sniper it picked one up i deleted it but same problem.
    guess i'll just have to use windvd to view mpeg2 dvd.
    i only preview them for sync probs anyway before authoring.
  10. sorry i could'nt let it lie.
    when i right click on the mpeg explorer.exe makes cpu goto 60% and available ram goes from 750MB to 250MB
    i have to open windvd first then open the mpeg from there for it to work.
    have been googling but no success.
  11. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    That's probably explorer trying to generate that preview, using DirectShow.
    /Mats
  12. as long as i open app first then the mpeg it is ok (except WMP)
    i was going wrong by right clicking on mpeg then > open with
    the registry can be edited to stop prview with avis but dunno about mpegs and im not going to try.
    thanks for help
  13. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Think it's the same reg hack regardless of file type.
    /Mats
