Hi,
I have the VIDEO_TS folder from a PAL dvd that I want to convert to NTSC. If I load the VOB files into my player, either ATI or NERO showtime I get both video and audio. If I convert the VOB to MPG with VOB2MPG 2.2 I get no audio on the MPG file.
I also tried using TMPGEnc Plus but the resulting MPG file still has no audio. The audio is obviously there in the VOB but every thing I use to try to convert it loses the stream.
Any suggestions?
Results 1 to 10 of 10
~dev
Ok, I found the setting for NTSC. But now what I do not understand is the DVD was just over 2gigs but at the end of the conversion the program says it needs a dual layer disc to fit it on.
~dev -
If the original audio was compressed to AC-3 or MP2 and you have now converted it to WAV (uncompressed) then the new audio will take more space on the disc. That's my guess.
*sigh* well I dropped the quality down a notch and it fit on one disc but the dvd runs for about 3 minutes then starts getting choppy and drops back to the main menu.
Just about ready to give up on this.~dev -
DivxtoDVD keeps compliant audio, and converts everything else to AC3 2.0. If your audio wasn't compliant your wouldn't get LPCM.
Are you using DivxtoDVD (free program) or ConvertXtoDVD ? ConvertXtoDVD has an option to include the original files when buring. This might well put you over the limits for an SL disc.Read my blog here.
Ok. I demuxed the files with Rejig, then transcoded the audio with BeSweet and am now reencoding with TMPGEnc Plus.
I will reauthor and see how it goes.~dev -
That worked out very well. There was quite a bit of banding and noise when there was quick movement but I was using a very fast encoding method. I am going to re-encode on high quality tonight and I should be all set.
Thanks!~dev -
I guess I am going to have to start over from scratch. Good thing I saved the Video_TS folder. All my original files got tossed and the DVD is now not reading. It was very scratched when I first began but now I cannot get any of my drives to read it.
*weep*
~dev
p.s. Thanks so very much to the godz who helped me here to get this working!~dev
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
ADS DVD Xpress CapWiz Woes
By yaddablah in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2010, 12:13 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 22:13
