Hi,
I try to backup a dvd, all is working fine except that the menu is not working. All the items not react to remote buttons. The menu works in computer (when I click on an item in powerdvd it works but the menu buttons are not highlighted, in the original it does)
The menu on this dvd is not a "true" dvd menu. Each animated item is a video (not referenced as a menu). They are referenced as titles in VTS 01.
In this DVD, the menu buttons are BOV (PGC Edit told me that). So how can I backup it with a working menu ?
I spent several hours with Nero Recode and DVD Shrink. Both are producing non working menu.
Are you setting the menu to any sort of compression in DVD Shrink? I never shrink my menus no matter how big they are because Shrink causes them to lose all functionality. If the menu is too big I usually replace it with a single still background picture and some new buttons. A reauthoring program would help you with this.
Yes I shrink the menu because It's about 850 MB (waste 20% of dvd is too much for a menu) and I try to reduce its size to the max.
I always shrink my menus to the max and I never had a problem.
Only this dvd is causing trouble.
EDIT: I just tried to backup the dvd by setting the menus to no compression bu it's still the same.
PS: One thing I forgot to say, the menus are stored in the "bonus" sections in Shrink and Nero Recode. -
Never test using the mouse, because it isn't same as using a remote. The keyboard mimics a remote much better.
I assume you are not using re-author mode and dragging these titles across to be backed up. In which case, it may just be a structure that Shrink isn't prepared for, and you need to look at an alternative backup method.Read my blog here.
R-click context menu for VLC and WMP - not working
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 16th Nov 2010, 07:44 -
shrinking a dvd file to email it
By Haopengyou in forum Newbie / General discussionsReplies: 9Last Post: 13th Jul 2010, 09:41 -
Converting & Shrinking to 1 DVD
By poppy56 in forum Newbie / General discussionsReplies: 4Last Post: 4th Oct 2008, 15:54 -
Menu buttons not working in standalone players
By pixiemyela in forum Authoring (DVD)Replies: 1Last Post: 5th Oct 2007, 17:20 -
After rip DVD menu not working, any suggestion?
By taylor6698 in forum DVD RippingReplies: 1Last Post: 3rd Oct 2007, 15:10
