I thought there was a crop that lets me select a specified section of the video and discard the rest. But I can't find them in the filter and resize is not quite right.
What I wanted was to get a portion of the viewable area to eliminate the extra on the sides and top. For example the video I have is 640x480 but it shows more than I wanted and I wanted to crop them using the crop area (example) from 0,24 to 500, 480
If that is the only filter you need then the fastest way is to add the Null transform (it does nothing but it exposes the cropping option), then click on cropping and adjust the x and y as needed.
This isn't necesssary but if you want to resize back to original resolution then add the Donald Graft's Smart resize filter after this (I prefer his) and set the resize options. -
Go to video , filter's ...
You will see "crop" box (greyed out) .
Apply resize filter , hit ok .
Now you will note the "crop" option is available
Do what you need now ...
Premiere Pro CS4 CROP feature
By CharlesLinquist in forum Newbie / General discussionsReplies: 2Last Post: 24th Jul 2010, 19:53 -
VirtualDub + Crop Filter adds a black border in right corner of video?
By CactusMan in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2010, 08:24 -
Handbrake: To Crop or Not To Crop
By meldavid in forum DVD RippingReplies: 1Last Post: 31st Aug 2009, 05:54 -
is it possible to crop a WMV file with virtualdub mod?
By sumeshkri in forum EditingReplies: 4Last Post: 13th Nov 2008, 21:26 -
Box crop for virtualdub
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2007, 11:06
