i have a video ts folder containing vobs. is there a way of finding out if these are ntsc or pal? my dvd player plays both but id like to find out which it is
There are some other methods as well. Open a VOB with IFOEdit and it will tell you what the resolution and frame rate are. Also, the free version of the Teco Bit Rate Viewer at http://www.tecoltd.com can tell you the resolution and frame rate. Before there ever was a Gspot, I used the commercial version of the Teco product.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Best Method Convert PAL VOBs to NTSC
By ehmjay in forum MacReplies: 13Last Post: 28th Jul 2009, 16:54 -
By ehmjay in forum MacReplies: 14Last Post: 1st Jul 2009, 23:54 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52 -
Are you able to join PAL and NTSC vobs together?
By ramrod1234 in forum Authoring (DVD)Replies: 12Last Post: 26th Apr 2008, 05:27
