Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. I just had my parents 50th anniversary party transferred from Hi8 to DVD.
    I have the files on my hard-drive.
    Because of the lighting in the catering hall, several moments or
    scenes are dark.
    Is there a program that can make these scenes brighter?
    Any help would be greatly appreciated.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    You could convert the VOBs back to MPEG-2 with a program like VOB2MPG and reencode them with a encoder like TMPGEnc and adjust the brightness there. Then you would have to author them back to a DVD. There would be some quality lost in the process.
    May 2001
    You can convert back to the original M2V file, then use AVISYNTH to adjust the scenes individually. You can then re-encode the video using your encoder of choice. Quality loss is minimal.
    I don't know if TMPGenc allows scene-by-scene adjustments, but AviSynth does. It CAN get to be tedious, but adjusting/re-encoding is the only way to get the video where you want it (other than changing the brightness/contrast on your TV as you watch).
    ICBM target coordinates:
    26 14' 10.16"N -- 80 16' 0.91"W
