hi,
i just recorded my daughters school play, and after about 1 minute into the tape there's about 40 seconds of black video and no audio. im trying to cut it out but a few seconds into the "black" i get this error.
audio samples ------- to ------- could not be read in the source. the file may be currupted
anyone?
Results 1 to 10 of 10
Coud you clarify please what software do you use and what kind of file (mpg, avi, dv) you are trying to cut?
my AVI Trimming guide
https://www.videohelp.com/forum/viewtopic.php?t=283241 -
How did you get the video from the tape to the computer? Does this black section appear when playing the tape in the camcorder?
Buy My Books -
It could be a corruption on the tape, but more likely it is a place where you stop shooting, then restarted after rewinding/fastforwarding, and the time stamp got screwed. Try setting your transfer software to transfer by scene, and it should (hopefully) transfer up to the blank, skip to the next scene, and transfer the next section. You can then join them, rather then try to edit bits out.
Read my blog here.
so i probably can't cut the bad spot out of this capture
and i should just recapture and just not capture that spot? -
That may be the bestter solution. Before you do that, try scanning for bad frames in virtualdub to see what it says
Read my blog here.
ok, i opened the avi and everything was greyed out except for for the input file button the file path, and the file file status which says"file reading error".
also, i snipped a few pieces from the end of the file,and ran it into the program and it gave all the info on that piece, and it said that the format said the file was dvsd.
is that some kind of compresion filter?
i captured with roxio 7.5 and set it to capure in dvd quality.
that's probably where i messed up.
thanks everyone
steve.
Avi chunk viewer?- what is this?!
By vanjo in forum Software PlayingReplies: 21Last Post: 29th Oct 2010, 03:20 -
Trouble ripping video and/or audio
By dexter30 in forum DVD RippingReplies: 8Last Post: 26th Feb 2010, 12:06 -
Trouble playing mp4 in VLC, audio is there, but no video
By brdhsby5 in forum Newbie / General discussionsReplies: 6Last Post: 9th Feb 2010, 14:06 -
AVIDemux 2.4.1 cutting audio or maybe video sync issue
By ColdFusion2 in forum LinuxReplies: 9Last Post: 11th Sep 2008, 11:27 -
Trouble getting video in time with audio
By JayxDee in forum ffmpegX general discussionReplies: 1Last Post: 27th Jul 2008, 09:36
