Hi there
I have a number of avi videos (xvid according to GSpot) and I would like to burn them to DVD. They are about 350Mb in size and about 42 minutes long (again using Gspot).
I have never attempted anything like this before but I've read a few guides on WinAVI convertor and TMPGenc / Plus and TMPGenc DVD Author.
I realise the file need to be converted to mpeg2 in order to play on a DVD player but I'm not sure which tools to use to get the best finished product.
I guess 2 x avi's per DVD for the best quality? The easiest and simplest way for a beginner to start would be good.
Any help, advice or pointing me to other guides much appreciated.
Cheers
Hi there
Thanks heaps for the replies. I'll download the trial version and give it a go.
As a matter for my own learning, if I was to get the best results with out an "all-in-one" program for a finished DVD what do you guys use?
Cheers -
My process is documented in more detail in several posts, but the nutshell version is
Video : Avisynth -> CCE -> mpeg veido stream -> DVD Lab Pro
Audio : Virtualdubmod -> Sound forge -> AC3 audio -> DVD Lab pro
Burn with Prassi OnesRead my blog here.
Hi thereOriginally Posted by guns1inger
Hmm, well I did ask
Thank you.
I've got a heap of learning to do.
Cheers -
If you're in reading mode, look under convert left. Select AVI to DVD, and you're likely to find more guides and method for this than you can imagine.
/Mats
Help needed adding Subtitles to Multiple Episode DVD with SubtitleCreator
By colditz in forum SubtitleReplies: 5Last Post: 20th Jan 2011, 20:41 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28 -
Adding multiple title tasks to a video
By nam207 in forum EditingReplies: 1Last Post: 22nd Nov 2007, 09:02 -
Adding Multiple Watermarks/Logos to a Video
By Moontrash in forum EditingReplies: 7Last Post: 23rd Sep 2007, 23:35
