I'm using Vegas to convert Wav files to AC3, as it gives me the best quality and least amount of problems.
Only issue is, i can only find a way to do it one file at a time, and its becoming very time consumin.
File open wav, wait for it to read the stream(1 min), render the stream as ac3, wait for this (5 mins), close project (if dont and add another file it adds to the file making it 2 files now), then open a new file continue.
What id like to do is just let it know i want all X files rendered as ac3, is there no simple way to do this?
Thanks!
This might be of interest http://www.vasst.com/search.aspx?entity=16&category=Freeware
Script at the top of the page called Trackaliser. You have to put all you audio on their own timeline first. Might be worth a go.Read my blog here.
batch rendering is built into vegas two ways ..
one - use the batch render script that comes with it
or
two - use the network rendering service (this can even run on the same machine) and load it up with projects , and it will do them all
for ac3 rendering - number one is the better ways to go"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
proxy editing and Batch converting in Sony Vegas Pro 10
By Domiel in forum EditingReplies: 3Last Post: 21st Nov 2010, 08:03 -
Vegas Batch Render?
By duderdude2 in forum EditingReplies: 1Last Post: 28th Feb 2010, 02:42 -
Batch render script in Vegas Pro 8
By schematic2 in forum Newbie / General discussionsReplies: 7Last Post: 18th Feb 2009, 18:14 -
Vegas 4 Batch Rendering
By schematic2 in forum EditingReplies: 0Last Post: 18th Nov 2007, 22:24 -
how do I batch render in vegas 7
By Jorge in forum Video ConversionReplies: 1Last Post: 25th Aug 2007, 19:02
