I hope someone can help me. I have used ffmpegx and followed ALL the instructions to get it to convert .ram files to DV...i place the .ram file i want to convert in the window and then in the source format window, the video and audio says no video and no audio and when i click encode i get this error and i get this error
Apple Script Error
Can't get text item 2 of "Binary file (standard input) matches". (-1728)
what does this mean? i mean i have downloaded all the files requested...download the files to convert real player files and renamed the folder and still nothing
help please!
Results 1 to 25 of 25
Is the extension of the file truly .ram? And, how big is it?
.ram files are usually just the information files that point to the actual RealMedia video/audio to stream, in my experience.If cameras add ten pounds, why would people want to eat them? -
hello and thank you for your responses. I did change the file from .ram to .rm and it recognized it in the open window up top but in the Source Format it stills shows no video and audio
and when I click encode it tries to encode it using one of the mencoder presets and its a 0K file.
Each .rm file is about 3.2MB...is that too big?
let me know what I am doing wrong.
Thanks for your help. -
Well, the type of .ram files I mentioned are usually only a few KB as opposed to MB, so... ^_^
Do the files play correctly if you load them in RealPlayer, or mplayer, with the appropriate Real packages installed? I'm not sure if mencoder/ffmpegx handles all the different compression methods used in RealMedia files... Major would be better able to answer that than I.If cameras add ten pounds, why would people want to eat them? -
Posting the actual process output (blue "i" icon in the Progress window) would help to determine the problem.
Major,
This is the message I get in the Process Output: (this after selecting AVI DivX in the target format window.
Do you think me being on a mac is the issue?
Encoding started on Fri Mar 3 17:42:45 EST 2006
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x351987
REAL file format detected.
Stream description: Audio Stream
Stream mimetype: audio/x-pn-realaudio
Stream description: Video Stream
Stream mimetype: video/x-pn-realvideo
Stream mimetype: logical-fileinfo
VIDEO: [RV30] 240x180 24bpp 15.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:11 fourcc:0x30335652 size:240x180 fps:15.00 ftime:=0.0667
Error: dlopen(/Library/Application Support/ffmpegX/reallib/cook.so, 1): image not found
Opening audio decoder: [realaud] RealAudio decoder
opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.so'
Read the RealAudio section of the DOCS!
ADecoder init failed
opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.so.6.0'
ADecoder preinit failed
Error: dlopen(/Library/Application Support/ffmpegX/reallib/cook.so.6.0, 1): image not found
opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.bundle/Contents/MacOS/cook'
Read DOCS/HTML/en/codecs.html!
Decoder init failed, error code: 0x80040005
Cannot find codec for audio format 0x6B6F6F63.
Opening video filter: [expand osd=1]
Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): image not found
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=240 h=128]
Opening video decoder: [realvid] RealVideo decoder
opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.so'
Read the RealVideo section of the DOCS!
VDecoder init failed
opening shared obj '/Library/Application Support/ffmpegX/reallib/drv3.so.6.0'
Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv3.so.6.0, 1): image not found
Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.bundle/Contents/MacOS/drvc, 1): image not found
opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.bundle/Contents/MacOS/drvc'
Exiting...
ideo format 0x30335652. -
i installed the one that was on the ffmpegx page. i read up on it and it linked to a page to download it. do you know a new site to get it from?
http://homepage.mac.com/major4/download.html i got it from this site and the link at the bottom where it talks about reallib version ..is this the wrong version? -
I went back to the site and was able to find another link to ge tthe Reallib folder. it had a lot more stuff than the previous link
its now encoding the .rm files to .avi mpeg 4
i guess now my question is how do i go about changing this to .DV so i can make it into a DVD movie
thanks you two for your help. -
Originally Posted by vipdigitalmedia
I tried .RM to DVD mpeg2enc and it would fail
i'm on a Mac...can I use Toast 7? i tried to put the files directly into iMovie but i would get an unknown error right when it finishes importing
also, i have 22 of these .rm files...each is about 2 min so I am wondering what owuld be the best way to handle this. Its 22 clips to one movie and I want to get each .rm file into a DV or some kind of file so i can go into iMovie to do some slight editing ( hoping to have the best video quality) and make it into one movie .
It would also create a MPG file first. And then you can use any authoring program like Sizzle or DVD Studio Pro to make a single DVD folder from many of them.
OK I have tried to convert my .rm files to DVD and i select DVD mpeg2enc and select encode with mplayer..in the video window i selected 4:3 and DVD and check: "encode video" and had no luck....
and when i tried to put the avi files i created using FFmpeg into iMovie to do some editing it would fail right at the end.
HEEEEEEEEEEEEEEELP.....lol
and after several minutes it says it failed and this is what i get
/Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.ff/: File exists
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
Mon Mar 6 00:52:02 EST 2006
-f 5 -b 234 -q 3 -B 260 -V 230 -a 2
-F 1
MPlayer dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
AltiVec found
CPU: PowerPC
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm:waveheader' '-v' '-osdlevel' '0' '/Users/vipdigitalmedia/Desktop/irmsvid22part01.rm' '-aid' '0'
get_path('font/font.desc') -> '/Users/vipdigitalmedia/.mplayer/font/font.desc'
font: can't open file: /Users/vipdigitalmedia/.mplayer/font/font.desc
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Unoptimized OnScreenDisplay
Using Darwin accurate timing
Terminal type `unknown' is not defined.
get_path('input.conf') -> '/Users/vipdigitalmedia/.mplayer/input.conf'
Can't open input config file /Users/vipdigitalmedia/.mplayer/input.conf: No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf: No such file or directory
Falling back on default (hardcoded) input config
get_path('irmsvid22part01.rm.conf') -> '/Users/vipdigitalmedia/.mplayer/irmsvid22part01.rm.conf'
Playing /Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.
get_path('sub/') -> '/Users/vipdigitalmedia/.mplayer/sub/'
[file] File size is 3479943 bytes
STREAM: [file] /Users/vipdigitalmedia/Desktop/irmsvid22part01.rm
STREAM: Description: File
STREAM: Author: Albeu
STREAM: Comment: based on the code from ??? (probably Arpi)
Checking for YUV4MPEG2
ASF_check: not ASF guid!
Checking for NuppelVideo
real: Header size: 18
real: Header object version: 1
real: File version: 0
Chunk: PORP (504f5250) (size: 0x32, offset: 0x12)
First index chunk offset: 0x35153f
First data chunk offset: 0x3c0
Flags (a): [perfect play (more buffers)]
Chunk: RPDM (5250444d) (size: 0xa4, offset: 0x44)
Found new stream (id: 0)
==> Found audio stream: 0
Found audio stream!
version: 5
header size: 70
frame_size: 558
ERROR: Could not open required DirectShow codec cook.so.
ize: 93
samplerate: 22050, channels: 1
======= WAVE Format =======
Format Tag: 28515 (0x6F63)
Channels: 1
Samplerate: 22050
avg byte/sec: 32115
Block align: 558
bits/sample: 16
cbSize: 18
Unknown extra header dump: [0] [5d] [0] [10] [0] [7] [2] [2e] [0] [8] [1] [0] [0] [2] [2] [0] [0] [18]
### skipping 0 bytes of codec info
Chunk: RPDM (5250444d) (size: 0x72, offset: 0xe8)
Found new stream (id: 1)
ADecoder preinit failed :(
ERROR: Could not open required DirectShow codec cook.so.6.0.
ERROR: Could not open required DirectShow codec cook3260.dll.
ERROR: Could not open required DirectShow codec drvc.so.
video stream: 1
video fourcc: 03VR (30335652)
H.263 ID: 30202002
Chunk: RPDM (5250444d) (size: 0x204, offset: 0x15a)
Found new stream (id: 2)
Got a logical-fileinfo chunk
### skipping 454 bytes of codec info
Chunk: TNOC (544e4f43) (size: 0x58, offset: 0x35e)
Chunk: ATAD (41544144) (size: 0x351189, offset: 0x3b6)
Packets in file: 4403
Reading index table from index chunk (3478847)
entries: 56
stream_id: 0
ERROR: Could not open required DirectShow codec drv3.so.6.0.
ERROR: Could not open required DirectShow codec drv33260.dll.
3479651
Reading index table from index chunk (3479651)
entries: 18
stream_id: 1
next_header_pos: 3479923
Reading index table from index chunk (3479923)
entries: 0
stream_id: 2
next_header_pos: 0
Auto-selected RM video ID = 1
VIDEO: 03VR [30202002,01A99030] 240x180 (aspect 0.00) 15.00 fps
Clip info:
name: Its Never to BIG
author: www.interracialmansex.com
copyright: ©2002 SiteX Internet Services
get_path('default.sub') -> '/Users/vipdigitalmedia/.mplayer/default.sub'
ADecoder init failed :(
Audio codec: [7] 32 kbps Voice
Audio bitrate: 32.041 kbit/s (4005 bps)
INFO: [yuvscaler] SVCD output format requested in NTSC norm
928 bytes for input buffer.
dec_audio: Allocating 128000 + 65536 = 193536 bytes for output buffer.
AUDIO: 22050 Hz, 1 ch, s16be, 32.0 kbit/9.08% (ratio: 4005->44100)
Selected audio codec: [racookmac] afm: realaud (Mac OS X RealAudio COOK)
Using (default) progressive frame mode.============================================= =============================
INFO: [yuvscaler] input: frame size: 240x180 pixels (64800 bytes)
INFO: [yuvscaler] input: frame rate: 15/1 fps (~15.000000)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: ?:?
INFO: [yuvscaler] from 240x180, take 240x180+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x360, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the BICUBIC algorithm,
sub-id: 0x01A99030
VDecoder init failed :(
realvideo codec id: 0x30202002 sub-id: 0x01A99030
ine switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] black lines: 60 above and 60 under
INFO: [yuvscaler] black columns: 0 left and 0 right
INFO: [yuvscaler] frame rate: 15.000 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 3
INFO: [yuvscaler] and is 1 to 2 for height
INFO: [mpeg2enc] Selecting SVCD output profile
INFO: RealVideo codec init OK!
Selected video codec: [rv30mac] vfm: realvid (Mac OS X RealPlayer 9 RV30 decoder)
can-data offsets to be filled in by "vcdimager"
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.ff.mpv
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
[libaf] Adding filter dummy
[dummy] Was reinitialized: 22050Hz/1ch/s16be
[AO PCM] File: audiodump.wav (WAVE)
PCM: Samplerate: 22050Hz Channels: Mono Format s16le
[AO PCM] Info: Faster dumping is achieved with -vc null -vo null
PCM: Info: to write WAVE files use -ao pcm:waveheader (default).
AO: [pcm] 22050Hz 1ch s16le (2 bytes per sample)
AO: Description: RAW PCM/WAVE file writer audio output
AO: Author: Atmosfear
it/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
INFO: [mpeg2enc] Progressive format frames = 0
/s16be -> 22050Hz/1ch/s16le...
[libaf] Adding filter format
[format] Changing sample format from big-endian 16-bit signed int to little-endian 16-bit signed int
[format] Accelerated endianess conversion only
Starting playback...
atrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] output: frame rate: 15/1 fps (~15.000000)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: ?:?
at, old len = 0, new len = 65538
VDec: vo config request - 240 x 180 (preferred colorspace: Planar I420)
Trying filter chain: vo
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
SwScale params: -1 x -1 (-1=no scaling)
Trying filter chain: scale vo
VDec: using Planar I420 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
VO Config (240x180->240x180,flags=0,'MPlayer',0x30323449)
SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
REQ: flags=0x407 req=0x0
VO: [yuv4mpeg] 240x180 => 240x180 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools
VO: Author: Robert Kesterson <robertk@robertk.com>
*** [scale] Allocating mp_image_t, 240x180x12bpp YUV planar, 64800 bytes
*** [vo] Allocating mp_image_t, 240x180x12bpp YUV planar, 64800 bytes
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
**** Your system is too SLOW to play this! ****
Possible reasons, problems, workarounds:
- Most common: broken/buggy _audio_ driver
- Try -ao sdl or use the OSS emulation of ALSA.
- Experiment with different values for -autosync, 30 is a good start.
- Slow video output
- Try a different -vo driver (-vo help for a list) or try -framedrop!
- Slow CPU
lay a big DVD/DivX on a slow CPU! Try some of the lavdopts,
e.g. -vfm ffmpeg -lavdopts lowres=1:fast:skiploopfilter=all.
- Broken file
- Try various combinations of -nobps -ni -forceidx -mc 0.
- Slow media (NFS/SMB mounts, DVD, VCD etc)
- Try -cache 8192.
- Are you using -cache to play a non-interleaved AVI file?
- Try -nocache.
Read DOCS/HTML/en/video.html for tuning/speedup tips.
If none of this helps you, read DOCS/HTML/en/bugreports.html.
demux_real: Found INDX chunk. EOF.
ds_fill_buffer: EOF reached (stream: audio)
d (stream: audio)
ds_fill_buffer: EOF reached (stream: video)
EOF code: 1
Uninit audio filters...
[libaf] Removing filter dummy
[libaf] Removing filter format
uninit audio: realaud
uninit video: realvid
Exiting... (End of file)
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 1868!
INFO: [mpeg2enc] Guesstimated final muxed size = 14405667
wait, encoding to mp2 audio with mp2enc...
INFO: Opened WAV file, freq = 22050 Hz, channels = 1, bits = 16
INFO: format = 0x1, audio length = 5505024 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
INFO: Avg slots/frame = inf; b/smp = inf; br = inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.ff.mpa"
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.ff.mpv looks like an MPEG Video stream.
INFO: [mplex] File /Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.ff.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.ff.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 23.976 frames/sec
INFO: [mplex] Bit rate : 234000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.ff.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 0471544
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16773
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 1867
INFO: [mplex] STREAM e0 completed @ frame 1867.
INFO: [mplex] STREAM c0 completed @ frame 5200.
INFO: [mplex] Multiplex completion at SCR=11242496.
INFO: [mplex] Video e0: buf= 237568 frame=001867 sector=00005924
INFO: [mplex] Audio c0: buf= 2080 frame=005200 sector=00001731
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 11873555 bytes
INFO: [mplex] Sequence headers: 125
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 1867
INFO: [mplex] No. Groups : 125
INFO: [mplex] No. I Frames : 125 avg. size 11621 bytes
INFO: [mplex] No. P Frames : 500 avg. size 5925 bytes
INFO: [mplex] No. B Frames : 1243 avg. size 6000 bytes
INFO: [mplex] Average bit-rate : 1219200 bits/sec
INFO: [mplex] Peak bit-rate : 1528400 bits/sec
INFO: [mplex] BUFFERING min 45254 Buf max 134618
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 3495072 bytes.
INFO: [mplex] Syncwords : 5201
INFO: [mplex] Frames : 5201 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
DVDAuthor::dvdauthor, version 0.6.10-2773.
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing /Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.ff.mpg...
WARN: not a valid DVD frame rate: 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
STAT: VOBU 16 at 1MB, 1 PGCS
STAT: VOBU 32 at 3MB, 1 PGCS
STAT: VOBU 48 at 5MB, 1 PGCS
STAT: VOBU 64 at 7MB, 1 PGCS
STAT: VOBU 80 at 8MB, 1 PGCS
STAT: VOBU 96 at 10MB, 1 PGCS
STAT: VOBU 112 at 12MB, 1 PGCS
INFO: Video pts = 0.186 .. 78.097
INFO: Audio[8] pts = 0.186 .. 125.010
STAT: VOBU 125 at 15MB, 1 PGCS
INFO: Generating VTS with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: ntsc
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
INFO: Audio ch 0 format: mp2/2ch, 48khz 20bps
STAT: fixing VOBU at 1MB (17/125, 12%)
STAT: fixing VOBU at 3MB (33/125, 25%)
STAT: fixing VOBU at 5MB (49/125, 38%)
STAT: fixing VOBU at 7MB (65/125, 51%)
STAT: fixing VOBU at 8MB (81/125, 64%)
STAT: fixing VOBU at 10MB (97/125, 76%)
STAT: fixing VOBU at 12MB (113/125, 89%)
STAT: fixed 125 VOBUS
INFO: dvdauthor creating table of contents
INFO: Scanning /Users/vipdigitalmedia/Desktop/irmsvid22part01.rm.ff.mpg.DVD/VIDEO_TS/VTS_01_0.IFO
Encoding completed on Mon Mar 6 00:58:29 EST 2006 -
yes i did..but for some reason it would cut the file time in half...for instance the clip is 2:08..and it would 1:17 and very fast...never understood that
man this is becoming problematic...i never knew it would be this difficult to change .rm file to .dv or DVD -
It's weird how none of that is explained on the Helix site, tho'. -
VIP,
You said you have Toast 7... I use ffmpegX, Toast 7, and MacTheRipper for a variety of tasks, and I have been able to convert to/from most formats.
If you just need a quick RM->DVD solution, Toast 7 can do this. Make sure to go and tweak the options (More button in video.) Unfortunately, you lose control when using Toast, but it might just be a quick fix until you figure out your ffmpegX setup for these files...
Matthew
Converting webm video files from YouTube
By henry33 in forum Video ConversionReplies: 2Last Post: 1st Nov 2011, 02:17 -
cropping or converting video files
By ggray000 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2011, 21:37 -
Problems converting video files .MOD to anything
By daka in forum LinuxReplies: 0Last Post: 24th Dec 2010, 14:16 -
Converting EF File Format in to Video Files
By Teac23 in forum Video ConversionReplies: 3Last Post: 23rd Jan 2010, 14:13 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33
