Wednesday, March 1, 2006 10:04:17 PM GMT
ProjectX 0.90.3.01 (31.01.2006)
-> working with collection 0
-> save normal log file
-> write all video data
-> write all other data
-> create *.idd Projectfile on demux: Mpeg2Schnitt idd version: V2/A3
-> patch c.d.flagged infos of pictures
-> add sequence end code
-> set resolution in SDE
-> PVA: strictly specs. for audio streams
-> VOB: determine diff. Cell timelines
-> TS: ignore scrambled packets
-> TS: enhanced search for open packets
-> TS: join file segments (of Dreambox®)
-> TS: generate PMT stream dependent
-> get only enclosed PES/TS packets
-> concatenate different recordings
-> ensure 1st PES-packet start with video
-> generate PCR/SCR from PTS
-> write output files to: 'E:\record2\E4'
-> Input File 0: 'E:\record2\E4\Beauty & The Geek 1x04.mpg' (1,127,637,053 bytes)
-> Filetype is MPEG-2 PS/SS (PES Container)
-> demux
-> found PES-ID 0xE0 (MPEG Video) @ 14
-> found PES-ID 0xC0 (MPEG Audio) @ 4124
-> video basics: 544*576 @ 25fps @ 0.7031 (16:9) @ 10000000bps, vbvBuffer 86
-> starting export of video data @ GOP# 0
!> dropping useless B-Frames @ GOP# 0 / new Timecode 00:00:00.000
!> dropping GOP# 1295 @ orig.PTS 01:27:20.551 (471649632)
!> Pics exp/cnt 12/18, inGOP PTS diff. 0ms, new Timecode 00:10:21.520
!> PTS difference of 86400 (00:00:00.960) to last exported GOP detected
!> dropping useless B-Frames @ GOP# 1296 / new Timecode 00:10:21.520
!> dropping GOP# 2285 @ orig.PTS 01:35:16.231 (514460832)
!> Pics exp/cnt 12/11, inGOP PTS diff. 0ms, new Timecode 00:18:16.160
!> dropping GOP# 2632 @ orig.PTS 01:38:02.311 (529408032)
!> Pics exp/cnt 11/5, inGOP PTS diff. 0ms, new Timecode 00:21:02.240
!> PTS difference of 43200 (00:00:00.480) to last exported GOP detected
!> dropping useless B-Frames @ GOP# 2633 / new Timecode 00:21:02.240
!> dropping GOP# 5638 @ orig.PTS 02:02:05.191 (659267232)
!> Pics exp/cnt 12/16, inGOP PTS diff. 0ms, new Timecode 00:45:04.560
!> dropping useless B-Frames @ GOP# 5639 / new Timecode 00:45:04.560
!> startPTS of GOP# 5905 is earlier than the end of last GOP.. (exp. 670844832)
!> dropping GOP# 5905 @ orig.PTS 02:04:13.351 (670801632)
!> Pics exp/cnt 12/12, inGOP PTS diff. 0ms, new Timecode 00:47:12.160
-> Video: fr/ ct/ 1p/ cg/ og/ dg -> 89236/ 5/ 7442/ 7437/ 0/ 5
-> Video length: 89236 frames @ 00:59:29.440
-> GOP summary: min. 20, max. 24 fields; contains interlaced frames
-> avg. nom. bitrate 2317725bps (min/max: 499200/4703600)
-> set first sequenceheader bitrate to 4703600bps
---> new File: E:\record2\E4\Beauty & The Geek 1x04.m2v
--> MPEG Audio (0xC0)
-> check CRC of AC-3 / MPEG-Audio L1,2
-> delete CRC in MPEG-Audio Layer1,2
-> add frames
!> 2 PTSs discarded in stream
Audio PTS: first packet 01:16:57.720, last packet 02:16:30.336
Video PTS: start 1.GOP 01:16:59.031, end last GOP 02:16:31.111
-> adjusting audio at video-timeline
!> missing syncword @ 29360, @ 00:00:00.000
!> found syncword @ 29696
-> src_audio: MPEG-1, Layer2, 48000Hz, stereo, 192kbps, CRC @ 00:00:00.000
!> missing syncword @ 14942913, @ 00:10:21.288
!> found syncword @ 14943432
!> 3 frame(s) (72ms) inserted @ 00:10:21.432
!> missing syncword @ 26348809, @ 00:18:15.864
!> found syncword @ 26349168
!> skipped sourceframe(s) @ 00:18:16.368
!> missing syncword @ 30342577, @ 00:21:01.824
!> found syncword @ 30342752
!> 11 frame(s) (264ms) inserted @ 00:21:01.968
!> missing syncword @ 64966689, @ 00:45:04.272
!> found syncword @ 64967072
!> 4 frame(s) (96ms) inserted @ 00:45:04.464
!> missing syncword @ 68033697, @ 00:47:11.328
!> found syncword @ 68034248
!> skipped sourceframe(s) @ 00:47:11.712
!> 23 frame(s) (552ms) added @ 00:59:28.896
audio frames: wri/pre/skip/ins/add 148727/0/2/18/23 @ 00:59:29.448 done...
---> new File: 'E:\record2\E4\Beauty & The Geek 1x04.mp2'
summary of created media files:
.Video (m2v): 89236 Frames 00:59:29.440 'E:\record2\E4\Beauty & The Geek 1x04.m2v'
Audio 0 (mp2): 148727 Frames 00:59:29.448 0/2/18/23 'E:\record2\E4\Beauty & The Geek 1x04.mp2'
=> 1,119,789,448 bytes written...
-> we have 37 warnings/errors.
