I have a couple of clips that are vp62 avi and I would like to convert them to mpg or even regular divx/xvid avi so I could convert them from there. I tried mencoder, a command line utility I use for converting mkv to avi, but it seems to have a problem openning the codec dll for vp6 (and it is the right version vp6.2). Any suggestions for an alternative or even explicit instructions for mencoder would be appreciated. Thanks.
Do you have the dll in your codec dir? No dll, no decoding since it is a proprietary format. dll is just the standard VfW codec. If installed, you can convert the avi via any app that uses VfW. VP6 also shiped with a dshow decoder.
use virtualdub
as far as i know mencoder uses its own codecs and does not use external codecs -
videocodec vp6 info "On2 VP6 Personal Codec" status working fourcc VP60,VP61,VP62 driver vfwex dll "vp6vfw.dll" out YUY2 out BGR32,BGR24
AVI to MPG with Mainconcept
By electrontau in forum Video ConversionReplies: 5Last Post: 1st Aug 2008, 14:34 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Problems decoding FLV4/VP62
By drwho in forum Video ConversionReplies: 1Last Post: 1st Mar 2008, 18:16 -
Playing "FLV4/VP62" via WMP9 /GSpot? (No Video)
By j_hallgren in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2008, 10:25 -
avi to mpg
By zoranb in forum Video ConversionReplies: 7Last Post: 12th Sep 2007, 15:09
