Dear friends
I'm converting an old VHS to DVD but the beginning of this sudio (+ or - 18 minutes) has a problem, it has alternating low volume (suffocate) and normal volume (good quality).
The remainder (after 18 minutes) has a good quality.
I'm using Audacity, there exists a filter tha correct this alternaing problem?
Thanks and sorry about my bad english.
Normalizing the whole track won't help if you have sections of normal volume. Have you tried processing the low sections independently? Select a section where it's low and normalize it by itself. I think you are going to have to do it section by section.
Steve -
Perhaps another way of wording it... In a different setup you might record the audio thru a mixer, turning the volume up when you needed to. Working with your already recorded (captured) audio, have to more or less do the same thing -- increase volume only when needed.
Software can't do it automatically because it doesn't know the volume's too low -- what if it was just really quiet? Ideally I think you'd use an envelope setup in something like Vegas, if I might suggest downloading the trial. You still would need to increase the volume for just those problem sections, but this would allow you to do it more gradually, with a taper rather then an on/off switch sort of thing at the begining and end of the selection.
That said, might look at some of the lower end audio apps -- the stuff bundled with programs like Roxio etc... Many have a feature for matching the track's volume for music CDs. *Might* be a way to get one of those to work I imagine.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 01:56 -
VHS/ DVD Go-Video problem. Bad video, good audio
By Shempp Ranger in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 20:31 -
VHS to DV - Audio not correct
By jlorelle in forum Newbie / General discussionsReplies: 13Last Post: 15th Sep 2008, 10:36 -
Help with VHS -> DVD using capture card (audio problem)
By dustin1 in forum Newbie / General discussionsReplies: 20Last Post: 7th Feb 2008, 23:27
