I have tried to install a couple of DVD apps and having a problem with them, in the process manager it shows them as loaded, but the apps wont load on my screen and I cannot use them, the problem first started with Memories On TV, the programme just wont load at all, but it shows in process manager, now I have tried to install DVD-Lab which I need to use, and the same thing happens, I tried to install ConvertX and it happens with this also, any ideas why DVD software like this wont load for me?? everything else works fine on my PC, I have the following installed (working fine)
Nero 6
DVD Decrypter
Alcohol 120%
Any DVD
CloneDVD2
IsoBuster
DVD Shrink
All of the above work fine, so why do some load and some dont?
my crystal ball is a little cloudy today.
perhaps if you filled out your profile with system details the clouds might clear. -
I had prob like that i ran a reg cleaner
WinASO Registry Optimizer is very good run it
reboot tray your progys this shood work google for it.
Bulldog57 -
tried the reg cleaner and although it fixed another prob I had, the dvd aps still wont load, any other ideas? could something be conflicting? If so I'm confused why Decrypter and Nero etc work fine, and Memories on TV and DVD-LAB dont.
sorry to triple post (frustrated lol) but does Memories On TV and DVD-Lab Pro require drivers for WinXP, I'm using SP2 are both apps compatible with SP2?
Sound wont work on KWORLD DVD Maker USB 2.0
By BiggerJim in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 07:06 -
dvd copied from HDD wont work on other players or computer??
By wundahoss in forum Authoring (DVD)Replies: 1Last Post: 8th Nov 2010, 17:34 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 15:41 -
DVD Decrypter wont work with my external drives?
By dazza555 in forum DVD RippingReplies: 4Last Post: 23rd Jun 2007, 20:04
