hi, im looking at the microsoft optical keyboard with fingerprint recognition found at this link
http://reviews.cnet.com/Microsoft_Optical_Desktop_with_Fingerprint_Reader/4505-3134_7-31139861.html
but the keyboard is already 18months old so im thinking its outdated
does anone have any suggestions for a great wirelss keyboard/mouse set
i need it to be able to do stuff like pause,rewind and stuff in a media player, also it has to be a bit stylish
anysuggestions before i go ahead and order the microst one, has anyone heard anything about this keyboard like common proplems
I don't know if it sells separately, but the keyboard that comes with Logitech's MX3000 set is awesome (http://www.logitech.com/index.cfm/products/details/US/EN,CRID=2162,CONTENTID=10709). I have it and love it, plus it has the media play buttons that you're looking for. It's got the volume control, play/pause, stop, fast forward, rewind, audio presets, burn, etc. The combo set also comes with software to help organize your media - I don't use it but maybe you would.
Logitech also has the MediaPlay Cordless Mouse which has all the media buttons as well (http://www.logitech.com/index.cfm/products/details/US/EN,CRID=2135,CONTENTID=9340). I almost bought this when I was shopping for a wireless desktop, but in the end I decided to save money and get the combo set. It looks and feels great though.
Both of these that I've mentioned are at the big electronics stores and I think at Staples as well. You should always go try out a mouse and keyboard before buying them to make sure you like the feel. They can have all the buttons in the world, but if they're uncomfortable to use then they'll still suck. -
order the microsoft, i want fiongerprint, my friend is this little rich genius, his room is locked with this fingerprint scanner on the door and he told me if i get someway to read fingerprints he will do the same thing for me, his fingerprint reader cos 1600 but mine cost 35,
well i orderd it, can i ask someone, will it work from the second i plug it in cos my ps/2 ports are buggerd
Good Long Range Wireless Keyboard/Mouse Solution
By greymalkin in forum ComputerReplies: 3Last Post: 1st Apr 2012, 19:49 -
ISO best wireless keyboard for an htpc
By Haopengyou in forum Media Center PC / MediaCentersReplies: 6Last Post: 15th Sep 2011, 11:27 -
can anyone recommend a wireless keyboard and mouse combo?
By mrgain in forum ComputerReplies: 3Last Post: 15th Jul 2009, 12:00 -
ADESSO Wireless Keyboard w/trackball
By budz in forum ComputerReplies: 0Last Post: 1st Dec 2007, 17:26 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Nov 2007, 00:56
