I've got some avi's that are encoded with wm9 vcm in an avi container.
I got errors from my media players:
VLC tells me it can't play wmv3.
MPlayer plays audio but no video.
I've installed FLIP4MAC but Quicktime says an "unknown error occured (-50)".
WMPlayer9 for OSX says the format is invalid.
The microsoft website says it's only supported in windows ( http://www.microsoft.com/windows/windowsmedia/9series/codecs/vcm/faq.aspx#VCM_1_2 ) but the I read of a linux codec available for mplayer.
So I checked the mpalyer website and it have a codec package
http://www.mplayerhq.hu/design7/codecs.html
but I don't know how to install them.
Here's the readme
I downloaded the mPlayer GUI pre-complied package.These are binary codecs for use with MPlayer. They are useless for normal
Windows players (like WMP, QuickTime, RealPlayer, ...) as they only contain
the DLLs without installer and other fancy stuff needed to use them with
common Windows players.
Put the files contained in this archive in a directory where MPlayer will find
them. The default directory is /usr/local/lib/codecs/ ($prefix/lib/codecs/) if
you are compiling from source, but you can change that value by passing the
'--with-codecsdir' option to './configure'.
If you use a prebuilt MPlayer package it will most likely be /usr/lib/codecs,
see the documentation of your package for details.
In the past /usr/local/lib/win32 or /usr/lib/win32 was the default directory,
some packages as well as a few other Unix players like xine and avifile still
use it, refer to their documentation for further details.
Can someone tell me how to install these codecs?
Thanks.
http://www.geocities.com/Tokyo/Bay/8128/
WMV3Server
To play avi files with WMV3/9 video and MP3 audio encoding on Mac OS X as of 2005-01-24 you will need:
Mac OS X 10.2 or later
WMV3Server
Windows Media Player 9 for Mac OS X
An .avi file containing WMV9 (WMV3) video and MP3 audio.
Instructions:
Launch the WMV3Server java application and click the "Open" button.
A standard open-dialog window appears. Either navigate to the avi video file or drag the file into the open window to have the window switch to the folder that contains the avi video file. Select the file and click the "Open" button or press return on the keyboard. The open-dialog window should close.
Next, click the "Start" button. The movie will be cached and WMV3Server will display "Server Started"
Open Windows Media Player 9 for Mac OS X. Pull down the "File" menu on the menu bar at the top of the screen and select "Open URL..." Enter the following address:
mmst://localhost:1755/
Windows Media Player should connect, buffer and play.
change an MKV container to AVI container???
By Spdngblt56 in forum Newbie / General discussionsReplies: 10Last Post: 17th May 2010, 22:23 -
converting MKV files in .avi container to dvd
By jamerican in forum MacReplies: 1Last Post: 27th Jan 2009, 11:29 -
How do you move files from .ogm container to .mkv container?
By VidHunter in forum MacReplies: 0Last Post: 8th Mar 2008, 19:19 -
Extraction of raw A/V from AVI container for files >4GB?
By alfonzo in forum Video ConversionReplies: 22Last Post: 11th Sep 2007, 08:18 -
Playing .ts files on OSX
By bvanbelle in forum MacReplies: 4Last Post: 21st Jul 2007, 06:11
